Results 1 to 12 of 12
Thread: Introducing the pHupinater!
    More spray then a speeding bullet! More powerful then a firehose! The pH-up-inater is the latest in pH up (TA not up) technology! Ok... so I just built it with a few parts, but I thought of a cool idea to attach a 3/4" pipe to it, and slide it into a slot under the diving board so it is neat and tidy. The kids can even use the board still.
    To turn it on, I disconnect a union to one of my returns, and attach this. Simple and easy. Thanks everyone for all your ideas found here that inspired mine. I can improve on this, but this is my prototype.
    While I am posting photos, I added these little adapters to my filter so that I could see air inside and also convert the threads on the filter to a union for easy hookup. God bless clear PVC... at $6/foot it better be good (only bought 2' ...
    Thanks all. Keep sharing your ideas...
    Josh S
    20.8k gal vinyl kidney; 600sqft surf area, Hayward 1HP Super; 300Lb Sand Filter; Aqua-Rite/T-9; RainbowRay LEDs, Jandy Deck Jets; and a whole 'lotta sweat n time...
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Introducing the pHupinater!
    You're done SLAMing when:
    30,431
    If it was on Facebook, I would "like" the pHupinator
    (Actually, I like it anyway)
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Awesome, I love it
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    My question is, does the phupinator effectiveness improve or decrease with a lot of diving action?
    The pHupinator is pHrackin cool!
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    wouldn't that be "pHrototype"?
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Thanks guys! (and no, the "pHrototype" is the aerator that the ring bearer in LOTR made...)
    Josh S
    Feb 2008
    Denton, TX
    5,061
    Cool! And if you happen to have any Olympic class divers using your pool, they will appreciate being able to see the surface of the water when diving.
    You guys are pHunny!
    Have others found that the water level drops faster and requires top up when aerating? It makes sense to me that it would - I mean, you are spraying water around - evaporation will happen.
    I think I need to top up about 1.5", but it has been about a week since I put the hose in. Does that seem out of wack?
    Josh S
    May 2011
    Orange County, CA
    696
    Clevah, very clevah!
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
