Thread: Average water loss?
    coffeegoddss's Avatar
    May 2012
    Minooka, IL
    93
    Average water loss?
    What is the average range for evaporation water loss? I was just curious.
    AG, 10,400 gallons, filter cartridge, 2HP pump
    Coffeegoddss...bonafide thread killer!
    POOL SCHOOL...fortheloveofgawd, read POOL SCHOOL
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Average water loss?
    I generally lose less than 1/2" per day no matter how hot it gets.
    Wind seems to affect it more than temperature.
    May 2009
    Mn
    198
    We lost about an inch this past week. It was super hot. I notice more loss when the cover is off...for obvious reasons. We keep our pool at 92 or above so at night we probably lose some due to evaporation.
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    Mar 2007
    San Rafael, CA USA
    12,082
    This map shows annual pan evaporation rates across the country where it's around 55" in Illinois. That would be 0.15" per day, but evaporation is higher in the summer because the pool water is often heated and the air is usually drier. It also depends a lot on wind. I usually double the annual amount for a rough summer limit so that would be 0.3" per day, but actual amounts would usually be less than that.
    With the intense heat I've been losing probably 1" per week. An average week is somewhere around 1/4-1/2".
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
