Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Removing rotten meat odor from travel trailer freezer/fridge
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Just wanted to see if anyone had any tips on removing the foul odor from rotten meat from a travel trailer freezer/fridge. We lost power to the fridge for two weeks. We've tried a whole bunch of stuff so far which has made it a little better, but I could use all the help I can get.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jan 2010
    Randleman,NC
    620
    Re: Removing rotten meat odor from travel trailer freezer/fr
    Baking soda....Place several box's in there..Keep them in there year around
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jul 2011
    Mesa Arizona
    190
    Can't help ya until we know your CYA level.......
    Mesa Arizona. Old school 26,000 gallon in ground plaster pool with sand filter built in 1984.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Set a bowl of white vinegar in there and close it up for several hours. Cut an apple in half, and replace the bowl of vinegar with the pieces of the apple and leave overnight. You will be amazed at the improvement.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    30,419
    3:1 diluted clorox along with some detergent. Chlorine will oxidize the organics causing the odor....just like it oxidizes the organics in your pool.
    Crushed up charcoal in a sheet of cheese cloth.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    X-PertPool's Avatar
    Exeter, PA
    1,385
    while I leave the trailer for a week, should I leave the doors open and the windows open in the trailer to air everything out? or should I keep the doors closed on the fridge and lock in charcoal,vinergar, or bowls of bleach to concentrate on that area
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Quote Originally Posted by Mesamav
    good one!!
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Quote Originally Posted by X-PertPool
    I've had the same thing happen to me.
    I opened the fridge and freezer and bleached every surface I could reach.
    Then a box fan was used to dry overnight.
    This process was repeated 3 times to complete the cleanup.
    19000 gal gunite,
    600 gal hottub,
    Intelliflo variable speed pump,
    Pentair 420 filter,
    Pentair 400k heater,
    Hayward Navigator Pro,
    TF-100
    Speed Stir ->->-> Great tool for easy testing
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Thanks for all the replies, so far I've been using a lot of bleach, the gaskets are the hard part as the multiple flaps in the gaskets make it hard to get in and hit every surface. I'm now using 409 spray (antibacterial) dimenthyl benzyl ammonium chloride 0.3% to spray inside the gaskets to hopeful hit the areas where I couldn't fit a rag soaked in bleach. I think I'm going to leave all the windows open and leave the fridge doors open (while off) to help air everything out.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If none of that stuff works, my family owns a janitorial supply business and one of the products we sell is called Consume by Spartan Chemicals, it is an enzymatic cleaner and one of its uses is removing the bad smell from dumpsters. If it can lower those odors it can help with almost anything, a 1 quart bottle should do what you need and should sell for around $6-8, you can find a local spartan chemical dealer from their web site www.spartanchemical.com note a little goes a long way, the key to success with it is repeat dosing every couple of days.
    Ike
    Jul 2009
    Olney, MD
    218
    A few years ago I brined a turkey in a beverage cooler. I cooked the turkey and completely forgot about the cooler for 6 months. Needless to say, it was nasty! I tried bleach, all sorts of cleaning products, it got clean but the odor just wouldn't go away.... until I soaked it in a solution of commercial sanitizer from Sam's club it is a quaternary ammonium compound solution. I just left it soaking overnight and rinsed it off in the morning and no more smell. If you give it a shot, I would try spraying or sponging some on the fridge and leaving the door shut for a while. "Proforce Sanitizer" (but you could probably find some other product with that active ingredient)
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Looks like a bunch of good ideas. I was gonna say shock with bleach/water mix in a spray bottle. That's how I clean the algae (mold from a leak) off the canvas of my popup camper. Good luck.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Feb 2009
    NW Chicago Suburb, IL
    75
    15,000 Gallon IG 15x30 fiberglass
    CoverStar auto safety cover
    SWG Aqua PL-PLUS
    Cartridge Filter
    240,000 LXI Heater
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    My grand parents never closed the camper/RV fridge once we got home and cleaned out the fridge. I think the door latch even has a latch the locks it shut while driving but can lock it open when in storage.
    I looked in a Dometic PDF LINK
    35. TO SHUT OFF THE CABINET
    If for any reason refrigeration is not required over a period of weeks, the gas taps or electric switch should be turned off,
    The cabinet and ice trays should be emptied, cleaned and dried and the door left ajar
    37. ODORS INSIDE THE REFRIGERATOR
    Odors inside the refrigerator are caused by improper food storage. They may also be caused by too infrequent cleaning of the food compartment or the refrigerator has been shut off for some time with the door closed.
    Reading this I guess they just closed the travel latch with the door open to prevent it from closing. They did this in every RV they owned for the 20 years I camped with them. My RV in my front yard has the fridge door propped open.
    -- Guy --
    X-PertPool's Avatar
    Exeter, PA
    1,385
    The reason I have rotten food is because I did something stupid. The fridge runs off LP but I turned the power off the the camper which means the electric ignition didn't have any power to light to keep the food cold. I'm silly like that.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    22,549
    The old models had a standing pilot but the newer ones have electronic ignition. Bummer when you disconnect the battery or let it run down.
    Butterfly's Avatar
    South Carolina
    10,045
    Well, you know that we at TFP love our sock methods............ :P
    Cotton sock full of coffee beans. Close the door so odors can be absorbed. Also, once cleared, you can keep a sock full of coffee beans (new one, of course )inside to maintain odor-free.
    You're done SLAMing when:
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Mmm, coffee.
    Mike
  20. Back To Top    #20
