Thread: New Here - little Cloudy
    Been lurking for about 2 weeks
    Made the switch to BBB out of Pool Store frustration
    Pool water is still a little cloudy but I think I am close
    Tried to shock last night
    Did an OCLT this morning
    Last night
    FC 22
    CC 1
    pH 7.4
    TA 130
    CYA 80
    This morning test
    FC 17
    CC 1/2
    water still slightly cloudy also
    Feels like I need to continue to shock until I pass the OCLT
    also still would like to slowly work down the CYA
    Thoughts?
    Doughboy Desert Spring 24 round
    1 1/2 HP Pump
    16,000 Gallons
    Sand Filter
    Jul 2008
    Seacoast, NH
    250
    Re: New Here - little Cloudy
    Yes, you do need to continue to shock until your overnight loss is no more than one. I suggest bringing to level higher than 22, say maybe 25 because if you start at 22 as soon as you lose any chlorine you are no longer at shock level.
    If you can bring down your CYA with a partial drain and refill quickly, it would be easier and cheaper to get to shock levels.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    30,419
    Refer to the FC/CYA chart in Pool School and you will find the target for CYA is FC = 31ppm. To perform the shock process effectively, you must replenish your FC back to that target of 31ppm continually or you will just drag out the process.
    Lower your CYA by drain refill down to around 50ppm and your shock target now becomes 20ppm.
    Thanks. Using the CYA chart just ran out of bleach last night. Bought more this AM at Sam's
    Thought we had it licked but got a little lazy
    Will crank up the shock again tonight and see if we can whip
    This site is awesome. Will not go into detail as my experience is like many others.
    but I can see light at the end of the tunnel.
    1 1/2 HP Pump
    16,000 Gallons
    Sand Filter
    Got FC up to 33 and CC .5 last night
    was FC was 25 and CC 1 this morning
    Cranked in more Clorox before heading out to work
    1 1/2 HP Pump
    16,000 Gallons
    Sand Filter
