Thread: Filter Suggestions Please?
    We have just setup our new 18x48 Intex Ultra Above Ground Pool and love it so far. However, we are wanting to upgrade the filter and are looking for suggestions?
    We are currently using the cartridge filter that came with the pool with 3 extra filters and change/clean the filters on a rotating basis. However, I would like to get away from the changing of the filters and have better "flow" into the pool to keep things stirring. I would also like to keep the cost at minimum... (I didn't say I didn't want to spend anything... I just want to do it as inexpensively as I can).
    Any suggestions?
    Thanks!
    _________________
    Don
    18' x 48" Intex Ultra Frame
    Intex 2650 Sand Filter and Pump
    BBB Method
    22,553
    Re: Filter Suggestions Please?
    Welcome to TFP.
    The Intex 2650 sand filter/pump combo is well liked and is much better than the cartridge filter.
    Welcome to TFP.
    Thanks for the reply Dave! Will the 2650 connect directly to the existing in/out's on the pool or does any modifications have to be made?
    I would still like to receive any other suggestions that others would have as well.
    Thanks!
    _________________
    Don
    BBB Method
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    The 2650 will come with it's own inlet and return nozzles which MAY be the same as you have on your existing pool. I believe the 18 foot Intex has the same nozzles. Even if it doesn't the holes in the liner should fit the nozzles which come with the filter. It's the perfect filter for your pool.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
