Thread: Pump stopped working Help!!!
    Came home today to find that the pump seperated from the motor. The pool is new and only running for 2 weeks. The store we bought it from is closed for the night so I loaded the pump and motor up and my wife will take it in to the store in the morning. Hopefully they can give us a replacement and I can have it back on tomorrow night. My question is what should I do to maintain my water until then. Should I dump some bleach in even though its not circulating?
    Thanks Jim
    17500 gallon Sharkline Morada PUR RTR 18X40 54 tall, 1.5 Hayward cartridge filter,
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump stopped working Help!!!
    Add some bleach and brush down the sides, that will mix it in.
    Feb 2008
    Denton, TX
    5,061
    That's about all you can do is just put bleach in and stir it manually.
    Apr 2012
    SW Ohio
    456
    The same thing happened to me a couple weeks ago I did just what they told you to do with no ill effect to the water balance
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Got the replacement pump hooked up and all is well. I dumped to jugs of bleach in before going to work, pull had full sun all day by the time I got home FC was still at 3. Looks like I dodged a bullet.
    Thanks for the help
    Apr 2012
    SW Ohio
    456
    Good job
