Thread: Just bought a filter and pump used. Um, help!
    Jun 2010
    Binghamton NY
    42
    Out neighbor put a working Hayward 1/2 HP pump and 200# sand filter on Craigslist. He ended up giving us a 3/4 one that siezed up as well. We have an Intex 15' pool with it's poor cartridge. I know we will need to tinker with hose fittings, but what other common pitfalls should we avoid? To show how green I am at this, the size of the sand filter totally floored me.
    Coast Spa Fitness Wellness Infinity Spa since June 2017. 5200 Gallons, Chlorine. Previous Intex owner.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Just bought a filter and pump used. Um, help!
    It should be about that simple, Hayward has made a number of different models over the years, it would probably help us if you can post pictures or at least the full model information.
    Ike
    Jun 2010
    Binghamton NY
    42
    I finally have pictures. This is the filter, the label is pretty worn. The most recognizable bit is "Rutgers St Belleville, NJ 07109". The pump is a Hayward.
    Jun 2010
    Binghamton NY
    42
    Me again. I left this up to my husband, and he choose to ignore it until after the pool season. Now we are looking to start up the pool, and are still staring at the same parts. Should I just try and dump this and buy a little intex sand filter? It really seems like overkill to have a 200lb sad filter for a 15' pool.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would try it...and it should be easy to attach to the intex pipes with pipe clamps I think. If it works, you pool will be we filtered.
