Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: TF100 Test Results Inconclusive- Now What?
    Jul 2012
    South Carolina
    48
    I am new to this pool testing process. I am going to have to "take over" for my husband. He has been adding soooo many chlorine pucks and bags of shock to try to combat algae. Therefore, my sister in law offered to come test using the TF100 kit. She has never seen the results I'll list below. I am wondering if we need to drain or 1/2 drain the pool, fill up, and retest to get some actual viable data to move forward?
    FC- did not turn colors...stayed clear, but cloudy
    pH- yellow...should have been orange or red
    TA- turned pink, not green
    CH- 300+ (only added 30 drops, still pink)
    CYA- 100+ (immeasurable?)
    How bad is it? We have a gunnite pool, approximately 15,000 gallons, clean with a polaris 360 vaccuum, currently using chlorine pucks, shock, and baking soda.
    15 K gallons
    Gunnite
    Centurion Pump/Hayward Sand Filter
    Polaris 360 Robot
    Re: TF100 Test Results Inconclusive- Now What?
    Welcome to TFP!
    Your FC is zero. Your PH is way way way too low. Your TA is zero.
    The extremely low PH can damage the pool. And you won't be able to deal with the algae until you get the CYA level down to something reasonable.
    I suggest you start adding borax (or soda ash, or PH Up) to try to get the PH up to at least 7.0.
    Meanwhile, work on replacing some water to get the CYA level down.
    Jul 2012
    South Carolina
    48
    Wow....I knew it's bad when I'm seeing sandy material in our vaccuum bag that is from the gunnite being eaten, I'm sure. Do you think draining and replacing 1/2 the water is the first step. Then, add borax and retest? Continue the process until the PH is up?
    15 K gallons
    Gunnite
    Polaris 360 Robot
    The PH is really really low. You want to start working on raising it right away. However, it is going to take a number of cycles of add borax, wait for it to mix in, test the PH, and repeat as needed. So you can mix that in-between cycles of draining and replacing water. That is to say, do one round of raising PH, do one round of replacing water, repeat as needed.
    Jul 2012
    South Carolina
    48
    Thanks so much. I've read up on this. So, how much borax do you recommend adding at one time and where is the best place to put it into the pool? How long do I let it circulate before replacing water and testing water again? I'm ordering my own TF100 kit but will use a storebought PH tester for now.
    15 K gallons
    Gunnite
    Polaris 360 Robot
    Jul 2008
    Seacoast, NH
    250
    I am an amateur at this and I defer to the experts, but might baking soda be better since her TA is zero? Cheaper and gets TA up a little.
    EDIT: after playing with pool calculator, I see why not baking soda. Raises TA, but doesn't do much for pH.
    According to pool calculator, 2 lbs of borax would raise your pH .23. One of the experts might tell you more, but you would certainly be safe with that if you want to start tonight. I spread it around the deep end and then brush if it doesn't all dissolve right away, but it usually does.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    May 2011
    Clearwater, FL.
    446
    Hi kwhyde and welcome to TFP!
    I put 2-3 boxes of borax in a five gal plastic pail full of water, mix, then pour in around pool.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Jul 2012
    South Carolina
    48
    Thanks so much for the posts....I'm off to Wal-Mart.
    15 K gallons
    Gunnite
    Polaris 360 Robot
    Jul 2012
    South Carolina
    48
    Ok...it's been 5 days since my beggining this post. I have since done the following:
    Drained approximately one fourth of the pool water and refilled. I've also put in 12 boxes of borax over the course of these days and allowed it all to circulate in order to get my pH up. My test kit came in today, and here are the numbers I think I've accurately gotten:
    I first used the K-100 Basic pH tester and got:
    pH 6.8 and the Cl Br side stayed clear
    I then used the TF 100 kit tests:
    FC- When I added the poweder, it turned very light pink only. Therfore, it only took 2 drop to turn it back to clear, so that's a 1 for FC, I believe.
    CC- again, ever so light pink, 2 drops, so a 1 again, I believe.
    TC- FC and CC combined, I guess, 2
    TA- The color turned a dark pink after 12 drops, so 120? Wasn't sure if this is considered "red" or it will be bright RED.???
    CH- It did turn Red, but when I added R-00012, it never turned BLUE, only light purple at 60 drops, so 600?
    CYA test- I know this and the pH was of biggest concern now. It is halfway between 100 and bottom of vile, 200 maybe? Still really high after draining one fourth of pool and replacing water.
    Do these numbers make sense together? Sorry it's so detailed....first time testing with kit, but followed the directions to the T. What do I do next? Drain more water and replace. Another round of 3 boxes of borax? I'm excited the pH has come up, but I think the other numbers are a mess. Thanks for the advice!
    15 K gallons
    Gunnite
    Polaris 360 Robot
    30,419
    1. drain at least 1/3 of your pool water...preferably half then refill and test pH and CYA.
    2. If CYA is still too high, you will need to drain/refill again to get your CYA down to around 50.
    3. Then you will need to shock the pool once your pH is in the 7's and your CYA is 50 or less.
    read "The ABC's of Pool Water Chemistry" up in Pool School, then read "How to Shock Your Pool".
    Disregard CH and TA for now.
    Jul 2012
    South Carolina
    48
    Ok...drained yet more water...one half, and refilled. Ph dropped a bit to 6.6 and CYA Improved some I believe to about 120. This test is tough because it's difficult to say exactly when I don't see a hint do the black dot, but I know it's not near 50 yet. To summarize, we've drained one fourth, replaced and now one half and replaced. Do I have to drain more? Did add 3 more boxes of borax today for pH. I'm sure there is little to no chlorine now too. We get are getting 9 full hrs of 93+ degree sunlight too. Will this increase my CYA levels too? What do I do now? Starting to get a bit frustrated....Still emptying ALOT of plaster gunnite material from our vacuum bag daily.
    15 K gallons
    Gunnite
    Polaris 360 Robot
    Jul 2012
    South Carolina
    48
    Ok...a new day of testing
    FC 1.5
    CC 1
    TC 2.5
    pH 7.2
    TA 110
    CH 390
    CYA still above 100 (120ish?)
    To this point, we drained and refilled one fourth, added borax to get pH up, drained one half more and replaced water only to have the CYA still be so high. We have full sun for 9+ hours daily at temps in the mid 90s. Is this adding to the high CYA too? I know we need chlorine, but Im not sure if i should put it in now or wait. I am deeply concerned because we are still vacuuming a handful of gunnite material from the pool daily. Please advise my next steps to ease my frustration. Thanks so much.
    15 K gallons
    Gunnite
    Polaris 360 Robot
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by kwhyde
    CYA goes up and doesn't come down expect via water replacement typically.
    If the pucks and the shock bags have been used a lot - CYA could have been upwards of 200.
    You will need to replace more water - but before doing that try diluting a sample of your pool water 50/50 with tap water and testing the CYA again. If you get a result like 60 then you know you are testing it right and you're on the right track - exchange more water.
    Remember if your CYA was 200+ and you have dropped 25% that at best you would have been around 150 after the first exchange of water. Then another 1/3 might have gotten you to 100 - but you're seeing 120 which would lead me to think your initial CYA was closer to 240. If you get through two more 25% exchanges you should be down to a CYA of 60 again and close to where you need to be. Then you can start the Shocking Process in Pool School.
    Jun 2012
    Mint Hill, NC
    2,589
    Also remember that as you change more water your fill water may change things also. The fill water will not contain CYA but may have high CH or TA and should be checked to know what the impact of the refills will be. If nothing else be sure to check the TA and CH and verify in the poolcalculator that your CSI index is in the right range.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    You need at least another 50% drain. No question about that. Might even take a little more than 50% but if you can get to ~60ppm the shocking process will be a lot easier on you. I know it's a lot of water, but once it's done and you never use solid chlorine again other than for vacations, your pool will be much happier.
    To answer your question though, nothing contributes to CYA levels other than CYA. Solid chlorine (trichlor pucks and dichlor powder) add CYA. CYA also can be purchased in powder and liquid form and added to the pool without chlorine. But other than these three sources, nothing else will raise CYA levels.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jul 2012
    South Carolina
    48
    Ok. Did the diluted CYA test...was between 60 and 70. So, I'm going to convince my husband that we need to drain again...50% of the water. I'll retest again when we are full. I'll pray this will do it and I'm not in debt for life over the water bill. We'll certainly make up the money in savings not buying pucks and powder shock, I guess. Thanks for the help!
    15 K gallons
    Gunnite
    Polaris 360 Robot
    Smykowski's Avatar
    Sep 2011
    3,065
    This is exactly right. It's hard to watch all that water run out of the pool, but take a look at your water bill and calculate exactly how much it will cost. Now, think about the last time you went into a pool store and bought exactly what they told you without really asking or understanding why. How much was that? Does that put it into perspective for you?
    I'm amazed at how many people come her looking for help, but balk at spending $60 for a kit, or $70 to replace water, but they'll happily walk into a pool store, and walk out with their wallets $250 lighter without a second thought.
    Getting your pool under control only seems like it's expensive because you're really paying attention to it. Stick with us, and I promise that long term, your pool will be far cheaper and far easier to maintain than anything the pool store can do for you.
    Jul 2012
    South Carolina
    48
    Halleluia...FINALLY...CYA is down after much draining....almost 100% new water. So.... You know my next question...... What now...
    FC- nonexistent.....no turning pink
    CC- .5
    TC- .5
    pH-7.2
    TA- 40 ( stopped the minute there was a full color change to pink/red, is that right? Not about intensity of color, right?)
    CH-150
    CYA- 45.....can u believe it?
    If I do the pool calculator, do I shock first and then add the borax and baking soda? Any particular order for things to be added?
    Shocking process next? Read the pool school but not sure what it means by bringing the pool to shock level. First time doing this...all advice welcome and appreciated!
    15 K gallons
    Gunnite
    Polaris 360 Robot
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Right now, I'd say you're in fairly good shape and may not need to shock. But only if you get the chlorine in right away. Tonight, raise the water to 9ppm FC with bleach. Check half an hour later to see if you hit 9ppm. An hour after that, see if you lost chlorine. (I am assuming you are doing this at night). If not, let it be overnight. Check for CC as well.
    If CC shows more than .5ppm, shocking will be in order.
    If your results show more than .5ppm CC, or if an hour later it's lost .5 or more ppm FC that indicates something is consuming chlorine. At that point, raise to shock level. Use pool calculator, set CYA in the now column to 45. The calculator will show you shock level at the bottom based on your CYA level. It's 16ppm btw.
    If doing this during the day, some chlorine will be lost due to sunlight so just watch it till the sun is off the pool and make sure it doesn't fall below 4ppm before the sun is off the pool (if it does, time to shock). If you lose 50% of the chlorine you started with, you're good. Re-dose to 8ppm for the night and let it go the next day.
    Leave pH and TA alone for now. After you've figured out if you need to shock, and complete that, TA should be raised to 70-80ppm but it's not essential to mess with it right now.
  20. Back To Top    #20
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    KW... I commend you. you asked for help, followed directions and are making great progress. Some of the others that have come here, ask for help, go to the pool $tore and get "help" and fool around for weeks and get frustrated. Especially, when needing to drain 3 times. It was Needed, not an option to get it fixed.
    When you get done, you will have a manageable pool that will be trouble free. No more pucks or bags for you!
    I am going to recommend the "feet draggers" read this thread.
    GREAT JOB!
    -- Guy --
