Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Opening Muriatic Acid Bottles
    Nov 2007
    Austin, TX
    69
    I've been lurking since last year when I purchased my home which had a pool. Reading the considerable knowledge base on this forum has been a real education and my pool is doing extremely well as a result.
    I had the pool re-plastered over the winter and as a result I am pouring in lots of muriatic acid to keep the pH in check.
    I'm sure someone has a fabulous trick to easily and safely open the muriatic acid bottles. Every brand I have tried comes with a seal under the cap that I find difficult to open. The best I have done is to punch a hole with a screwdriver and use pliers to pull it off. It just doesn't seem it should be so hard. I wash off the tools right away, but I am sure I am damaging them.
    What do others do?
    Thanks -- Marc
    My Pool
    15k Gal Gunite Pool w/8 ft Spa w/Spillover
    Hayward DE Filter + DE Separation Tank
    Legend Sweep, Pentair Gas Heater
    Stenner Metering Pump for Liquid Chlorine Injection (15 gallon tank)
    IkeRay's Avatar
    Houston, Tx
    154
    I take a pocket knife and cut off the plastic cover, then rinse off the knife in the pool before dumping in the acid.
    I also wear a mask and gloves since the few times I didn't I was coughing up a storm...
    30,000gal In-ground Gunite Pool DE filter
    Polaris 380 APC
    BBB method all the way - Newb, like to absorb info and chatter, but take the experts' advise
    Guest
    I put on a rubber glove (the disposable kind), use a wooden shish kabob skewer to punch a few holes in the liner, then use the gloved hand to remove the liner and rinse everything in the pool.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I use a plastic knife from Wendy's. Has a fairly sharp point, and won't react if I get MA on it. Dunk it in the pool when I'm done.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Marc and welcome to TFP!
    Have you seen SeanB's promo? Check it out, you might win the TF Test Kit!!
    http://www.troublefreepool.com/about4922.html
    You're done SLAMing when:
    Jul 2007
    Sahuarita, AZ
    278
    I just lay the bottle on it's side with the opening pointing in the general direction of the pool, take a running jump and STOMP on it! BTW, I'm going through shoes and pants an a pretty rapid rate, is there a forum to discuss that?
    Actually I find all the gloves and goggles and hazmat suits pretty funny. I just use a pocket knife to cut open the seal, pull it off with my bare hands and throw it out. I wash my hands when I'm done but that's about it... of course I'm only able to find the 15% acid around me so it's half as strong as what most of you are probably using.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    Jul 2007
    Katy, TX
    188
    I just use rubber gloves and then use my thumb to poke a hole .. walaa!
    ~Andrea
    24,000 IG with spa and 4 ton waterfall. Equipment: Pentair 520 Clean & Clear, Pentair VS+SVRS Intelliflo, Pentair Whisperflo 2 HP, Polairis Cleaner, Intellibrites, Pentair Rainbow 320 in-line Chlorinator, Pentair Easy touch 8 wireless and spa side remote.
    Nov 2007
    Austin, TX
    69
    Re: Opening Muriatic Acid Bottles
    Thanks for all the replies everyone.
    Now I'm thinking about adding borax to slow the pH rise. The combination of new plaster and the aeration from the spa spillover has me adding acid almost daily.
    Cheers all,
    Marc
    My Pool
    Round Rock, TX
    529
    Quote Originally Posted by EskimoPie
    Pictures please!
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Aug 2007
    Austin, TX
    343
    I switched to the pH Adjuster from HASA which use dry acid. I too have a new pool and had to add a little acid daily. I still have a few bottles left. I do the same as above, poke a hole then pull out. It's interesting to open a bottle when it's a bit humid out.
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Mar 2008
    Wake Forest, NC
    128
    Same here, real men don't need no stinkin gloves.
    Actually it is a little bit of a concern. If you are right next to the pool how much can you hurt if you get a drop or two on your hands and just rinse it off right away? I cut mine with an old knife and rinse all of it in the pool knife, hand and the seal.
    I will admit I didn't know about the fumes and opened my first a few weeks ago down wind. NEVER again will that happen wow.
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
    Aug 2007
    Powhatan VA
    50
    LOL sefrlw ... the exact same thing happened to me too, wasn't expecting it. I actually got a little weak in the knees for a second. Agreed, never again.
    20x40 IG Vinyl
    33k Gallons
    Triton TR-100 Sand Filter
    Pentair WFDS-6
    Mar 2008
    Central VA
    328
    Maybe I partied too much in my 20's, but I kind of like the fumes...
    Kidding, of course. I don't use gloves, either, but maybe I should, that stuff is potent!
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    Guest
    If any one is interested, those fumes are hydrogen chloride gas. Once they react with moisture (such as in your nose and lungs) they from hydrochloric acid once again. (I am sure you are all aware that muriactic acid is just a name for 31% or less hydrochloric acid and that when dry acid is dissolved in water it does form sulfuric acid. )
    Jul 2007
    North of Dallas
    207
    so, what are you saying bear......
    I just take the cap off, and find a small pointy rock in the landscaping that surrounds the pool to pop the seal off and then rinse my hand in the water in case anything got on me. Then, I'll slowly pour it in around the edge of the pool by the different returns. I'll make one full pass around the pool with the jug spreading it out as much to help it dilute.
    If your careful, there's not a lot of danger in it and you have 10s of 1000's of gallons to rinse off any that may get on you, just go slow, be careful and watch out for the fumes. I still have my 10 fingers and not any new ones growing yet, so I think I'm still okay at this point.
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    RedishConstruction.com
    Guest
    Quote Originally Posted by sredish
    I am simply saying that muriatic acid, dry acid, and other pool chemicals need to be treated with respect and common sense.
    Mar 2008
    Wake Forest, NC
    128
    Please don't take my man comment as a lack of respect! I agree totally with the bear be careful. I wish I new about the fumes the first time!
    Guest
    Quote Originally Posted by sefrlw
    I didn't. I am probably one of the biggest 'cutups' among the mods except perhaps for the mermaid queen. Just read some of the stickies I wrote to get an idea of my twisted sense of humor!
    Aug 2007
    Austin, TX
    343
    You have to be to have a yellow Hummer! (Btw, outstanding article!)
  20. Back To Top    #20
    Feb 2008
    Denton, TX
    5,061
    I also use a sharp and pointy rocky to open it. Once the opening is started, I can pull it off by hand. I do wear PVC gloves and chemical handling goggles. Wash with soap and water when I am done.
    Anybody know why the label on the acid bottles reads that it is for use in pools and RVs? What would you need HCl for an RV for?
    Craig
