Thread: GRRRRRR!!! Can't win for losing...
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    I finally get all my chemicals perfectly balanced and what happens you ask?......Well let me tell ya. I noticed the water was a little low the other day, so I added some, because it has been extremely hot, with very little rain, I never gave it a second thought. I added water again last night thinking, hmmm, that's a little odd, I'd better keep a check on that.
    I went out this morning to do my OCLT test and that water was down about an inch, so I knew it was a leak, but where? Welp, I found it. One of the blocks that the pool was sitting on had cracked and shifted it's way part way under the liner. I don't know how long it had been like this because it's under the deck and behind the ladder of the pool. It was just a teeny tiny little hole, so I thought OK I'll just throw a patch on and watch it. As SOON as I touched it, it split wide open into about a 2 inch long gash. That was the end of that.
    So to get to my question....I ordered a new liner, should be in by Thursday. It won't be installed until Sat. at the earliest, possibly even Monday. I've already turned my pump off and am just letting it go until then. It's not holding water anyway, even though, I duct taped the heck out of it. My question would be, how much water can I safely lose without the pool collapsing. This is my biggest fear. Any help or reassurance would be deeply appreciated.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Re: GRRRRRR!!! Can't win for losing...
    well if you dont have a big windstorm you may be okay.. if the liner is no good any ways and really worried about it get some 2X2 or something to prop it up? I knowI had my pool drained for about 5 days.. and it was fine.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Thanks for the reassurance. No more windstorms I hope. We has that derecho thing go through her a couple of weeks ago. What a mess! Over half of the state without power. Thankfully I didn't lose mine, but my neighbors did for 8 days. I just got the yard cleaned up, still have a pear tree that snapped in half to take care of. I'll keep the 2x4's in mind. I finally got the water to go from a raging river to a swift trout stream with the duct tape. I just hope it won't be too wet to lay new block.
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    So sorry to hear about your troubles, it can be very frustrating I know, and I feel your pain.
    Question? how thick were your pavers, and did you have them turned side ways or length wise?
    When we "finally" get to put our pool up we are going to use 4" thick pavers, 8"x16" and they will be turned side ways, so there is less paver inside toward the liner, I am even considering trying to put some kind of foam or rubber on the edge of the pavers on the pool side just for this very reason.
    Good luck, I hope everything gets better for you.
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Dangit, that sucks. I think it's also my biggest fear with pavers, and part of why I didn't use them. We used 1/2" wooden boards (fence boards) under the feet, they're small and don't shift, nor are they tall enough to pierce the liner. Working 3 years so far.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Thanks all! yeah, the pavers are sideways and I'm not sure how thick. The installer brought them, they don't look to be 4 inches though. Upon further inspection, it looks like it was set too far back to begin with. I guess on the bright side is that I'm upgrading my liner to what I want and I'm getting it at cost. I found the same one online and it was still $10 more (on sale) than what I'm paying.
