Results 1 to 11 of 11
Thread: Taylor 4088
    May 2012
    South Florida
    36
    Taylor 4088
    Where do you read the CYA level on the Taylor 4088. On the fluid line or somewhere else?
    IG ~14,000 Gal
    Pentair clean n clear Cartridge 100g/
    SWG Aquapure 1400
    Hayward XL Cleaner
    Premix Marbletite Freestone series
    1.5Hp 2 speed
    TF-100
    May 2012
    South Florida
    36
    Taylor 4088
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
    Montreal Canada
    326
    Re: Taylor 4088
    You bring the slider up to the point where the black dot just disappears. You read the CYA value at the water level.
    May 2012
    South Florida
    36
    Re: Taylor 4088
    Thanks, that's what I thought but I wanted to be sure
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
    Montreal Canada
    326
    Re: Taylor 4088
    Grab the high resolution product picture of the (old) K-0203, the CounterLab, off of Taylor's site, you'll get the full instructions - they're displayed prominently on the faceplate of the CounterLab.
    May 2012
    South Florida
    36
    Re: Taylor 4088
    looked for it, couldn't find it
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
    Re: Taylor 4088
    There is some discussion of the procedure in this topic.
    Aug 2011
    Metro Atlanta, Georgia
    161
    Re: Taylor 4088
    If Mr Chlorine Powder (CaOCl2) would double check this, I believe this is what the instructions to the Taylor #4088 are:
    Cyanuric Acid Test:
    1. Rinse and fill CYA cylinder (# 4088) to A mark with water to be tested.
    2. Add R-0013 to B mark. Move test stick up and down to mix for 30 seconds. WAIT TWO MINUTES. Read before five minutes.
    3. Raise test stick, then slowly lower until the black dot on the test stick just disappears when viewed from the top.
    4. Read test stick at liquid level. Record as parts per million cyanuric acid.
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    Montreal Canada
    326
    Re: Taylor 4088
    Quote Originally Posted by scarob63
    Home Page > Services > Marketing Support > Product Photography > (Click Agree) > High Resolution Product Photos > Scroll down to K_0203_2048_1536.JPG
    Re: Taylor 4088
    The photo confirms Buford's text.
    Jun 2012
    NJ
    50
    Re: Taylor 4088
    From looking at a picture of it (as I don't have it), I would believe you'd read it at the fluid line. So when you move the black dot up and down, wherever that fluid line is on the scale when the dot disappears would be your CYA level. I'd think this would allow you to save some reagent if you know your CYA levels are higher (vs filling the entire tube).
    EDIT... and when I say save some reagent, I'm just referring to saving some with the 4088 as it requires significantly more reagent than the other taylor test (with just the black dot at the bottom where you need to add liquid until it disappears). I believe the 4088 requires 20ml of reagent vs 7ml with the other test.
    Never mind.. I see this was answered in a duplicate thread.
    Topics merged. JasonLion
    24,000 gallon in-ground plaster, Pentair FNSP60 60 sq. ft. DE filter @ 9,000 GPH, 2HP WhisperFlo pump, CircuPool RJ45 SWG, 399k BTU Raypak heater, built 2008. Taylor K2006C kit.
