Results 1 to 12 of 12
Thread: Stinky Water?
    Jul 2007
    Sahuarita, AZ
    278
    Stinky Water?
    What can cause the water to be smelling stronger than usual? I noticed a couple of days ago and my wife has really been noticing... its almost like a smell of something breaking down in the water... once I found a mouse in the skimmer and this kind or reminds me of that smell. Problem is there is nothing in the skimmer at the moment other than a few bugs and leaves (the usual). I don't have any combined chlorine either which I'd usually take to be a source of odor. My levels are:
    FC: 4.5
    CC: 0.0
    TC: 4.5
    PH: 7.7 (could use some acid)
    TA: 90
    CH: 270
    CYA: 70
    Salt: 3800
    Temp: 85
    Any thoughts? Water is clean and clear as always. The only thing I can think of is that it's been pretty windy this week and maybe lots of dust and dirt is blowing into the pool and breaking down... but wouldn't that show as CC?
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Have you checked the pump basket? Are there any lines, like a cleaner line or spa lines that don't have water flowing through them regularly? My first thought is just shock the pool and see if it clears it up.
    You might also look for a dead animal somewhere near the pool instead of in it.
    Jul 2007
    Sahuarita, AZ
    278
    Quote Originally Posted by JohnT
    Yeah I checked the skimmer basket... it had a few leaves and bugs in it but nothing big... There is a waterfall that doesn't get a ton of use... that's a thought... maybe I should set the Easytouch controller to run the waterfall for a minute or two every day just to flush out the lines with fresh water regularly.
    My Pool:
    Jul 2007
    Sahuarita, AZ
    278
    Thats a thought, but it's not that strong of an odor, I'm talking very faint but still noticable... My wife was wondering if the chlorine was way too high because it just smelled like strong chlorine to her, but I don't think 4.5ppm should be that noticeable. Like I said though it's not very strong so it could be just normal and we're a little extra sensitive for some reason.
    My Pool:
    SW Indiana
    9,198
    Are you smelling while in/near the pool or after getting out? The chlorine in the water on your skin will convert to CC after you leave the pool, and can have an odor.
    Jul 2007
    Sahuarita, AZ
    278
    Both actually... a few days ago while swimming I kept smelling a faint persistent odor. It seemed strongest near the water level... Then yesterday while running errands around town after swimming my wife complained of the strong odor on her skin and irritation. Normally I'd think these symptoms would be a case for shocking but with my good chemistry levels and 0.0 CC I hate to shock if I don't need to. Again, it's faint so we're probably going to give it some time and see if it persists... we have some friends coming over this weekend too so we'll see if they notice anything odd.
    My Pool:
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    EskimoPie
    I have the same odor problem in my new pool.
    We opened it on May 31st. All water chemistry is good.
    Smells like rotton eggs. Most of the adults didn't smell anything.
    I smelled it and it was a faint smell on top of the water.
    Could it be the gas bubbles from the SWG coming to the surface when we splashed atound in the water?
    FC 3
    TC 3
    pH 7.6
    Alk 90
    CA 250
    CYA 80
    Water is clear as a bell.
    The only thing I can think of is to clean the filters again.
    Have you found the source of your smell?
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    rotten egg smell sounds like a sulfur problem. Did you fill with well water?
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    iggy's Avatar
    Jan 2008
    175
    Quote Originally Posted by Molson
    No it was city water and had been fill in Janauary.
    he smell of rotten eggs was from one of the young swimmers said it smelled like.
    I peronsally think it is the outgassing of the water from the SWG.
    Still not sure.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    The rotten egg smell is a metabolic byproduct from sulfate-reducing bacteria. Here's an excerpt from Wikipedia:
    "The rotten egg odor of hydrogen sulfide is often a marker for the presence of sulfate-reducing bacteria in nature.[1] Sulfate-reducing bacteria are responsible for the sulfurous odors of salt marshes and mud flats, as well as intestinal gas. Sulfate-reducing bacteria slowly degrade tough-to-digest materials that are rich in cellulose in anaerobic environments.[1] Rather than breathing oxygen, they "breathe" sulfate. Sulfate occurs widely in seawater, sediment, or water rich in decaying organic material."
    Note especially that last sentence. Could leaves or other organic matter have gotten into the pump strainer basket?
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    iggy's Avatar
    Jan 2008
    175
    Quote Originally Posted by AnnaK
    My filtering system is probably the cleanest on the planet. LOL Since the pool was finished in late Janauary 2008 I have cleaned the filters twice and plan to do it again in the next day or so. Here in Arizona we have mostly blowing fine dust. The way my back yard is very little leaves from the plants ever get into the pool.
    I appreciate your research and will continue to try and figure this out.
