Results 1 to 19 of 19
Thread: Can you reduce or eliminate salt taste in a chlorine pool
    May 2011
    Venice - Sarasota Florida
    30
    I have two pools in Florida, one commercial and one residential. My customers always say we have a salt water pool, or ask why it tastes salty. Both are standard chlorine treated pools.
    Any solutions to reduce the salt taste short of replacing the water.
    Thanks
    Kevin
    Venice Beach Villas
    37,391
    Re: Can you reduce or eliminate salt taste in a chlorine poo
    What do you use to add chlorine? Liquid chlorine adds salt, although I do not think the concentration in the pool gets very high normally ... like maybe around 2000ppm. SWG want it up around 3200ppm and most people can not taste that. I myself think I can tell a difference around 2000ppm.
    Either way, who cares what some people think the water tastes like ... it should not be causing a problem.
    Have you test for the actual salt level?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I would tell them it's not a good idea to be sampling the water with their mouths!!
    May 2011
    30
    The pool uses liquid chlorine. The residential pool is manually added, the commercial is aromatically added with a Stenner feeder. I will get the pool tested for salt level, never the less it still has a salt flavor and the customers pay the bills. Does anyone have a recommendation for how often pool water should be changed out (not easy when your running a business.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Have you always owned these pools? Or are the a recent acquire? Could it be that they were salt water pools?
    Are the bill payers complaining or inquiring?
    Salt doesn't go away, it has to be reduced via changing the water, might not require a total water change.
    You could just say yes it is a salt water pool........
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    May 2011
    30
    Owned both pools about 10 years. The commercial pool water was replaced about 5 years ago. I am confident they were never salt water pools by the age of the equipment when purchased. Both pools can be viewed at www.venicebeachvillas.com
    Some customers comment, not a real show stopper. The question is can the salt tastes levels be reduced. If the answer is no, it would be great to know.
    Jun 2010
    Glendale, CA
    513
    All sources of chlorine are going to add salt that builds up over time. Liquid chlorine will add add more salt than a solid chlorine source - but they all add salt.
    In a year round commercial pool this might add up to a lot of salt after a few years. You could easily be adding somewhere in the neighborhood of 2000-4000ppm per year in salt minus whatever water replacement is going on.
    It might be interesting to measure the salt content of the pool to see if the comments are warranted. You may find it is pretty high.
    Other than draining the pools every year or two - not sure there is anything that can be done about the taste.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    30,107
    I think folks are not giving you a direct answer because the question is so unusual. To my knowledge, we have never had an objection to salt taste on the forum in 5 years....even in salt pools.
    Short of a drain/refill (if your salt level is really that high) I can think of no solution.
    Mar 2007
    San Rafael, CA USA
    12,082
    I use winter rain overflow where I live to dilute the water each year. This keeps the salt level in the roughly 1000-1500 ppm range and it doesn't taste salty to me, but everyone has a different taste sensitivity. For chlorinating liquid and bleach, for every 10 ppm Free Chlorine (FC) you add you are also increasing the salt level by 17 ppm when accounting for chlorine usage/consumption. So at 2 ppm FC per day, that's an increase in salt of about 100 ppm per month. Adding acid also adds to salt (chloride). You can only keep the salt level down through dilution of the water. Don't forget also that for plaster pools where you may add calcium chloride to increase Calcium Hardness (CH), you may start off with 350 ppm salt even if you started from scratch.
    Feb 2008
    Denton, TX
    5,061
    Tell them to have a beer. That'll get rid of the salt taste.
    May 2011
    30
    Thanks for the great responses. I appreciate them. Probably the best bet is to replace the water, something I was hopping to avoid. Or put up with it ?? I will get these pools tested for salt level and post it back as an FYI.
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    I would think you have salt blowing in from the ocean, as well as folks using the pool to rinse off after being in the ocean?
    Dan
    16' X 24' Wilkes Pools "Genesis", 10K Gal
    Hayward Powerflo Matrix 1 hp, & 18" Pro Series sand (S180T)
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Funny, I was just reading a decent article about TDS when I stumbled shortly after onto your thread!
    http://ppoa.org/pdfs/What%20is%20the%20 ... Solids.pdf
    If you go by this article, the high TDS contribution by Sodium Hypochlorite is contributing significantly to your salt levels. Certainly every Pool Plant course I have completed has erred caution in the use of Sodium v Calcium hypochorite for High TDS levels. In a backdoor kind of way this could be argued that high TDS = high salt levels = salty taste in the water, supporting an argument to use Calcium Hypochlorite as opposed to Sodium Hypochlorite (bleach.)
    That is not a reccomendation to switch santisisers, merely an observation on your post, and some food for thought for you to digest, you will also notice an interesting piece in the article about using a de-salinator in your plant room would actively reduce the salt level.
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    Aug 2009
    SW Wisconsin
    518
    you should try a SWCG that uses 5600ppm to run!! My pool does, and yes the water "tastes" a bit salty, but nothing that causes anyone to say "yuck" I can't swim in that.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Mar 2007
    San Rafael, CA USA
    12,082
    See Certified Pool Operator (CPO) training -- What is not taught for more info on the side effects of different chlorine sources. ALL sources of chlorine increase the salt level because chlorine becomes chloride when it gets used/consumed. Chlorinating liquid, bleach and lithium hypochlorite add additional salt upon addition so net add twice as much as Trichlor and Dichlor, but these latter two increase Cyanuric Acid (CYA) instead and that's far worse. Cal-Hypo adds additional salt but about half as much as the other hypochlorites, but it also increases Calcium Hardness (CH) which can be a problem if CH levels are already high.
    Remember that the PPOA articles generally refer to commercial/public pools with high bather loads. In residential pools where the daily FC usage may be 2 ppm, the salt level using chlorinating liquid or bleach rises by about 100 ppm per month so not that bad, though if there is no water dilution at all then this can build up over years.
    South Central NJ
    3,192
    Add to that that most people can't taste it until the slat level is at least 6000.
    Scott
    Owner of - PoolGuyNJ LLC
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Quote Originally Posted by flyweed
    And I thought mine was high at a requirement of 4500!!
    Hey venice,
    Next time someone comments on the salt taste just tell them that you added salt to the pool because of the soft feel of the water on the skin. All you gotta do is put a positive spin on it and most people are satisfied.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Pointyhead's Avatar
    May 2012
    Central Georgia
    113
    Quote Originally Posted by 257WbyMag
    I was gonna say limes and tequila.
    10 year old 18x32 inground, vinyl liner 1 year old, 25,000 gallon Grecian, Hayward ST244 Sand Filter, 1hp Hayward pump, Diving board, Side Steps, Koolcrete decking located in middle [s:37hekvij]earth[/s:37hekvij] Georgia.
    Aug 2009
    SW Wisconsin
    518
    OR.....next time someone complains about the salt taste..you can say.."Darn kids must be peeing too much in the pool again"...LOL
