Thread: Do I need to acid wash the concrete before the new plaster?
    Aug 2010
    Charleston, South Carolina
    77
    I'm just finishing up my new inground, pool and I was wondering if I should acid wash it or just clean it with a heavy duty concrete cleaner before I have the quartz finish applied on Friday. The pool was shot about 3 months ago and I've always pumped out any water that accumulates when it rains. The shotcrete looks pretty good, it had quite a bit of sand in it from climbing in and out over the past 3 months doing the tiles and stuff, but that's about it. I swept it out this morning. Is a full-on acid wash necessary or can I just pressure wash it with a good concrete cleaner/degreaser?
    16' x 36' - 19,000 gallons
    Pentair Intelliflo variable speed pump
    Easy Touch automation
    Intellichlor SCG
    Triton II sand filter
    KrystalBlue KrystalKrete Quartz finish
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Do I need to acid wash the concrete before the new plast
    You're done SLAMing when:
