Thread: TA PPm Calculation
    TA PPm Calculation
    Does anyone know/understand how the "poolcalculator" figures out TA concentrations? I am having trouble duplicating the TA result generated by the poolcalculator. Given a volume of 20,000 gallons (US) and 0 ppm TA, the calculator generates a result of 563 oz (35 lb) of baking soda required to reach 120 ppm. However, (35 lb) / (20,000 gal x 8.35 lb/gal) x 1,000,000 = 210 ppm. Does anyone know how the calculator arrives at 120 ppm?
    Re: TA PPm Calculation
    Welcome to TFP!
    By convention, TA is measured as ppm of CaCO3, even though that isn't what you are adding to raise TA. The difference between Ca and Na are ignored, as they have no real impact on the chemistry.
    To adjust the molecular weight you multiply by the weight of CaCO3 (84 ish), divide by the molecular weight of NaHCO3 (100 ish) and then there is another factor of 2 (which I always get wrong, but roughly speaking that is why they call it bi-carbonate).
    Ah, I knew there was a molar ratio involved! So, TA is really a measure of the carbonate ion concentration, that's why you divide by 2 at the end. Thanks!
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, carbonate ions can accept 2 protons so count twice towards TA. So you need half as much carbonate as bicarbonate in molar units.
