Results 1 to 10 of 10
Thread: Water Pressure
    Jul 2007
    Hillsborough, NC
    525
    Water Pressure
    Just for full disclosure, we got our pool used. It was put up new for 2010 season, but HOA made the original owner take it down. They used it for that season while appealing, etc just to be able to use it. I don't know if it was taken down in the fall or spring of 2011. I got it last summer and everything sat till this spring. After I had everything hooked up, the first thing I did was backwash for several minutes. The pressure gauge was broken so I replaced it. The new gauge has the water pressure at 17 PSI consistently since I put it in. Last weekend vacuuming a lot of **** after 2 storms, the pressure didn't really go up, I expected it to. After vacuuming again and backwashing yesterday, the pressure still neither rose nor fell. Is it just I have a really clean pool? Or maybe I am not backwashing/rinsing well enough? How much of a change in pressure should I expect before having to backwash?
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    22,553
    Re: Water Pressure
    That's a small filter for that pool so that's why the pressure is high. I'd pay attention to the flow out the return to gauge when to backwash. When there's a noticable difference I'd backwash.
    Jul 2007
    Hillsborough, NC
    525
    Re: Water Pressure
    Just out of curiosity, what size filter should I have for this pool? According to Hayward's specs on the filter, it can handle the GPH rating on the pump plus a little more.
    Jul 2007
    Hillsborough, NC
    525
    Re: Water Pressure
    Oh, with the pressure already that high, I got a bag of DE today intending to add some to the filter. Should I be worried about the slightly increased pressure I will have using the DE?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Water Pressure
    For your 10500 gallon pool a minimum sand filter size of 2.0 sq. ft. is recommended. Your current filter is 1.76 sq. ft., so it is not too far off. What matrix pump do you have?
    Quote Originally Posted by crokett
    Should be okay, since you should be only raising the pressure by 1 psi when you first add the DE. Have you read: http://www.troublefreepool.com/pool-..._a_sand_filter
    Jul 2007
    Hillsborough, NC
    525
    Re: Water Pressure
    Yes, I have read the pool school link on adding DE.
    My pump, not sure the specific model # but I know the nameplate says 1.5 HP. I also know that motor ratings are sketchy and can mean more or less whatever the manufacturer wants them to mean.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Water Pressure
    That 1. 5hp matrix is a bit big for that filter, which has a 35 gpm rating and the pump is probably pushing closer to 55 gpm through it if you have fairly normal plumbing sized at 1.5" diameter.
    Jul 2007
    Hillsborough, NC
    525
    Re: Water Pressure
    Hmm... is that a problem for the pump and/or the filter? I don't really have the money to replace a filter that is working just fine.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Water Pressure
    Sort of both, you filter is too small for your pool (though it's close) and your pump is too big for your filter and could be channeling your sand.
    When you did backwash how long did it take for your water to run clear?
    When your pump is off is your pressure gauge reading 0?
    Bottom line, if you pool is crystal clear, then the filter is doing it's job.
    Jul 2007
    Hillsborough, NC
    525
    Re: Water Pressure
    The sight glass runs clear in a minute or so, but I've never really timed it. There is a little bit of sand in the sight glass. I haven't ever been able to get that out. I don't get sand in the return though, at least as far as I know. When I turn the pump off the pressure drops to 0. As you said, the filter is working, the pool is perfectly clear. I guess for now I won't borrow trouble. I will keep an eye on things and come fall if there are no issues till then will take the valve assembly off the filter and look at it. Will I be able to see the sand being channeled?
