Results 1 to 8 of 8
Thread: How often will I add bleach for day-to-day maintenance?
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    I am trying to set expectations with our new pool. How often do you all add bleach to maintain proper CL levels? From reading posts, it seems like this is a daily or at least every-other-day process, which is not a big deal of course. Also, I am more curious about this as it relates to the summer months. I am in Houston, TX, pool specs are in my sig.
    Also how often do you perform TF-100 (or similar) tests? Do you only use a TF-100-style kit for testing or do you supplement that with strips and then perform a TF-100 test if the strip results look suspect?
    With a new pool, I want to make sure I do everything possible to prevent problems that are within my control. If that means daily testing and adding bleach daily (among other things), then that's what I'll do.
    Thanks in advance for the info!
    18,000 gallon in ground, plaster - completed 6/29/12
    Jandy 340 sq ft cartridge filter
    Jandy variable-speed 2 HP pump
    Jandy LXi 400 heater
    Jandy Aqualink PDA-PS4
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: How often will I add bleach for day-to-day maintenance?
    My $0.02 based on my experience in blue below.
    Quote Originally Posted by AaronGo
    I am trying to set expectations with our new pool. How often do you all add bleach to maintain proper CL levels? From reading posts, it seems like this is a daily or at least every-other-day process, which is not a big deal of course. Also, I am more curious about this as it relates to the summer months. I am in Houston, TX, pool specs are in my sig. You're about right. Every day to every other day. If we're going for 3 or 4, I can raise the FC above the top of the normal range, put on the solar blanket, or both, and it's fine when we come back.
    Also how often do you perform TF-100 (or similar) tests? Do you only use a TF-100-style kit for testing or do you supplement that with strips and then perform a TF-100 test if the strip results look suspect? See above. My suggestion is to test every day until you get to learn how your pool behaves based on temperature and bather load. Once you get a good feel, you can go less often. That said, the only time I test less than once a day is when I'm travelling for work. If I'm home, I test. As for strips, I threw mine out.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Test and adjust FC and ph daily using the k-1000 kit
    Preform Fas/Dpd anytime you're worried at all about chlorine levels (storm, party's, sudden drop in FC)
    Test TA weekly
    Test cya and ch monthly or anytime you add fresh fill water.
    You'll learn your pools habits as you test. For me.....I've maybe tested 3 times ever for ch, but do the fas/dpd test often.
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Thanks for the feedback. I can see why you threw the test strips out. I have used them a few times and I can't really tell what color they have changed to. I thought it was perhaps that particular brand, but that seems to be a constant theme on this site. Figured I'd ask to be safe.
    There is definitely a learning curve and I expect to better understand what our pool needs and how often after a few weeks, so I will plan on doing daily tests with the TF-100 until I truly understand its behavior. I am hoping the test kit arrives in a few days, I ordered it on Sat.
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Quote Originally Posted by Leebo
    Test TA weekly
    Cool, I will set up a schedule for this. I read that it's best to do the test around the same time if possible, with a slight advantage to testing in the evening.
    I am one of those "spreadsheet" types, so I plan on keeping a log of the results so I can understand our pool. It's an ecosystem after all, so it's good to know how it reacts to certain variables and stimuli.
    Part of me is stressing a little about being one of the unfortunate ones whose pool gets cloudy or worse, so I really want to maintain the pool we have now (which is a clear, clean pool). I suppose it's natural feeling for a new pool owner.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    It only seems like a lot at first, after a couple dozen tests you'll be a pro, after a few dozen you'll have it memorized. After while you'll start to know what "normal" is for your pool and you'll probably be able to skip to testing FC and Ph every other day (under normal circumstances).
    I picked up a speed stir last year and now I do the FC and Ph at the same time using 2 separate test tubes, the whole thing takes about 5 minutes.
    Jul 2011
    Eastern Ohio
    7,075
    I missed the fact your pool is a plaster pool. At first I would suggest testing the CH MUCH more often, maybe even as often as every other day.
    Articfox918's Avatar
    May 2012
    Western, Wisconsin
    99
    Sounds like your there just need that little push of encouragement! I'm one of those spreadsheet guys too! so your not alone. I test every night at the same time enter my data into my spreadsheet add my usual amount of chlorine and done! 5-10 min max. As all here have said after a few tests you'll have it mastered and wont even think twice about doing it.
    The best part is getting to the point of realizing by the type of day, weather, sun, bather load...etc you can pretty much predict what chemicals and the amounts you will need to add. ****Disclaimer....This doesn't mean blindly throw in chemicals please still test and use pool calculator don't use the Dion Warwick method***
    POOL SIZE: 27 FT round 52" Deep on edges 66" Deep in center
    FILTER TYPE: Hayward Sand Filter
    PUMP SIZE: Hayward 1 HP Pump 60GPM
    FILTER SIZE/FLOW RATE: Unknown
    HEATER: None at the moment but in process of making my solar panels should be operational by next season!
