Results 1 to 10 of 10
Thread: Filter issue
    Filter issue
    I have used the green to blue product out by hth. I thought it would be okay since I have a regular sand filter. The problem is that when I am vacuuming up the material in the bottom, the filter is sending the nasty water back into my pool. Everything I vacuum up is floating again. I have backwashed over and over again. It doesn't help but for a minute or two and then it starts again. What do I do?
    Can I vacuum pool on a backwash setting? I currently vacuum on filter setting. PLEASE HELP. I have friends coming over in 2 hours and prefer my water to not be disgusting.
    Springfield, Missouri
    18 x 36 vinyl IG, 3' 10"- 8' depth. Hayward Max Flo 1 1/2 HP VS pump, Ranger 30" sand filter, 2 skimmers, 2 main drains,3 returns, 2 colorlogic lights, and 3 Jandy deck jets
    30,395
    Re: Filter issue
    Have you tried to vacuum to waste?
    Re: Filter issue
    how do i do that?
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Filter issue
    You should see a setting on your multiport valve for Waste. As you vacuum the water (and gunk) will be discharged through the drain port. What is the model of your filter?
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Re: Filter issue
    I have a sand filter also, when I vacuum I turn my filter to the waste setting and vacuum, this makes all the dirty water go out of the filter rather then through it. What filter/pump setup do you have?
    13500 gallons
    Intex 2650 Sand filter pump
    AG
    Jul 2011
    Mesa Arizona
    190
    Re: Filter issue
    I'm no expert and still somewhat of a newbie here but I put some DE in my sand filter and it cleared things up very nicely in a few hours. There was a huge difference in my pool in the first two hours of filtering with some DE. My sand filter doesn't have a port for vacuuming to waste so I had to do it this way.
    I add the DE directly into the skimmer basket. Just a few cups and I was good to go. Watch the filter pressure though. The DE cleans the water very well so it makes your filter pressure rise pretty rapidly. If that happens, backwash and add a little less DE.
    Oh, mix the DE in a bucket of water before adding it to the skimmer. Just a couple cups or so. Not too much or you filter pressure goes out of sight very quickly.
    Mesa Arizona. Old school 26,000 gallon in ground plaster pool with sand filter built in 1984.
    Re: Filter issue
    I did the vacuum to waste and it worked. Thanks everyone!
    Re: Filter issue
    Question based on this thread
    If you vacuum on waste how much water are you are you throwing away each time you vacuum?
    24 Ft Sharkline Matrix , ~15,200 Gallons
    Pentair SD60 w/ 2 speed 1.5 HP Dynamo pump
    Taylor K-2006 --- BBB
    Re: Filter issue
    it can vary depending on how big your pool is. I usually can vacuum a few days in a row before I need to add water.
    13500 gallons
    AG
    Re: Filter issue
    Quote Originally Posted by wwhite0310
    Thanks for the reply
