Page 1 of 8 1234 ... LastLast
Results 1 to 20 of 146
Thread: Finally under construction in Midlothian, TX
    Karmann's Avatar
    Apr 2012
    DFW Texas (Midlothian)
    123
    After lurking on TFP for a while researching what type of pool to build, speaking with builders and starting our construction a few weeks ago I feel I should introduce myself and share some pictures.
    Iím a complete pool owner newbie, so I ask a ton of questions and tend to overthink sometimes to foresee any future issues and prevent them in the beginning.
    I have to thank this site a ton for the valuable resource itís given me to answer most of my questions.
    Iíd love to hear some thoughts on my questions below
    - Best pool brush on the market opinion, anyone use a king-fin did you like it?
    - Does having almost solid rock beneath my pool benefit the gunite structure and help prevent soil movement?
    - I went with a heat pump for my spa since there isnít any gas line in my city and I didnít like the thought of a propane tank, I wonít be using the spa in freezing temps so does this sound like a decent idea?
    - My heat pump has a chiller option for cooling the pool in the heat of the summer, how much of a delta should I expect from ambient temps?
    - If you could redo your pool build again, what would you do different (on the advice of my brother I went with extra decking and larger spa)?
    When we started
    Digging Finished
    Steel and plumbing mostly done
    Gunite done
    Martin,
    Midlothian, TX
    Pool built in August 2012, 17.2k gallons, IG Gunite/PebbleTec (Midnight Blue), 1k sq ft Washed Aggregate decking, Jandy Stealth 2HP Pump shared with Spa, Aqua-Pure Salt-Gen, Jandy 1.5hp wtr feat pump, Jandy CV580 Cart Filter, Jandy AE3000TR Heat Pump w Chiller, Polaris 280 with Booster, Dual Time Clocks with freeze protect feature, Jandy Pool (2) and Spa (1) Multi LEDs, 2 Skimmers, 4 Pool Returns, 6 Spa Jets, water features incl 3' sheer descents and spa spillway
    Click Here For My Pool Build Thread
    Karmann's Avatar
    Apr 2012
    123
    Re: Finally under construction in Midlothian, TX
    here is a diagram of what the completed pool will look like (we made a slight change for a full spa seating bench)
    as a reference our patio is about 42' long
    Martin,
    Midlothian, TX
    Jul 2012
    Murrieta, CA (SoCal)
    7
    Looks very nice. Pool is about 16x32?
    Karmann's Avatar
    Apr 2012
    123
    very close, it's suppose to be 17x38' per the contract and depth will be 3.6'-5'-4' since none of us are swimmers we're really looking for a playpool
    Martin,
    Midlothian, TX
    Karmann's Avatar
    Apr 2012
    123
    My tile and stonework started yesterday here are some more progress pics...
    I'm super happy with the progress since i'm less than 3 weeks away from when they first broke ground.
    Martin,
    Midlothian, TX
    That is an unusual treatment around the rim of the spa, I haven't seen that done before but so far I like it! Maybe it is also because I really like your tile. Is the mosaic on the spa the same as the waterline tile? What tile is it?
    We also picked a gray/rust natural looking tile from Master Tile, Afrika series, Nairobi. We will start construction before the end of the month.
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    Karmann's Avatar
    Apr 2012
    123
    Thank you, the pool builder called it a rolled edge and our thought was it would be more comfortable on our backs than normal rock coping when lounging in the spa.
    The spa tile and the pool tile are from the same series and we think it will go well with the mossy rock flagstone and boulders surrounding the spa. I think it's a little off color from the multi colored Oklahoma flagstone we used for the coping but Iím being optimistic since I've seen them together in a same pool before and it didn't look too bad.
    I think the tile is from Noble Tile, but I don't see it online.
    I've asked the builder to get me samples and part numbers in case we need them in the future so I'll post the info when I get it.
    Martin,
    Midlothian, TX
    That's a beautiful design. We are near Midlothian, and our builder does that rolled edge too on the spa.. I love the tile you chose. It goes great with your rock and flagstone.
    So many choices...
    They just broke ground on ours today. Right at about 2 feet, the excavators ran into solid rock - ugh. They are hammering it out right now. I guess we won't have to worry about the pool shifting too much down the road. As soon as I have some good pics, I'll post some.
    Good luck!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    Yukon Jack's Avatar
    May 2011
    Rose Hill, KS
    94
    That looks great - bet you can't wait for the first jump into it!
    18x33 AGP, 17,300 gal, Hayward Sand Filter, 1.5 HP 2 Speed Hayward Pump
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Hitting rock in Texas is a good thing. The pool structure will have a solid foundation, so much less shifting to happen. If they did not hit rock, they would be recommending soil injections. Either way, it costs some money, but you should have a great result.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Congrats on the pool and thanks for the pics!
    Heat pump with the chiller option is the coolest thing I've heard! I myself am waiting for the pool to start. My thread is new-construction-in-dallas-tx-t48111.html
    I have already been doing research on cooling the pool, b/c I read so much about this time of year and 85+ pool temps worry me. I would be glad to read the options on this myself.
    28,500K, 520sqft cartridge filter, prism quartz pebble antigua, Pentair Intelliflo SWG, Pentair Legend Platinum robot, date TBD
    Quote Originally Posted by elwood58
    I was hoping! Thank you! Going to download pics and start a new thread. Still watching the progress on my Midlothian neighbor.
    Helen
    Karmann's Avatar
    Apr 2012
    123
    I'm glad to hear having so much rock under my pool is a good thing. My builder was actually one of the few that didn't charge a premium "on paper" for hitting rock.
    Martin,
    Midlothian, TX
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    You are going to love that chiller option. Nothing like working in the yard all day and taking breaks to hit the 82 deg pool for a quick cool off. Very refreshing.
    But I dont see a gas heater in your specs. That heat pump will take a loooong time to heat the spa, and wont do it at all in teh colder weather.
    While they are running the gas line, get it stubbed out near the equipment pad for a possible future upgrade.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Karmann's Avatar
    Apr 2012
    123
    thanks lerchac, I was hoping someone in here would chime in that the chiller option on our heat pump is worth it.
    Our city doesn't have gas lines and I went with a heat pump instead of burying a propane tank. I understand it could take a few hours to heat the spa and we can't use the spa in below freezing temps but this was considered ok with us instead of dealing with propane lines and heater refills etc...
    The Jandy AE3000TE unit also has a defrost option to run in cooler temps but we don't really expect to be using the spa in December/January months. We'll see how this season goes I guess, fingers crossed we're happy with the heat pump
    Martin,
    Midlothian, TX
    Karmann's Avatar
    Apr 2012
    123
    stone and tile was finished today and i must say we're pretty happy with it
    Martin,
    Midlothian, TX
    Jul 2012
    Oklahoma City
    72
    Wow, very nice!!
    Flagstone deck and SWG work because of sealer?
    I'm afraid to show my wife the pics!
    IG gunite Edmond, OK(OKC), 18x36 freeform ~20K, 4-8' deep, Pentair equip, (2) 3hp VS+ pump, 520 cart filter, 3 LED, Easytouch8, ItellichlorIC40 SWG, Polaris 3900 cleaner, Spa 8'x18"raised, 20' raised bond beam 2 sheers, Stonescape Tahoe Blue quartz plaster, TF-100 kit.
    Feb. 25, 2014 dig started, May 24, 2014 filled.
    Karmann's Avatar
    Apr 2012
    123
    Quote Originally Posted by Flatlander
    Wow, very nice!!
    yes, the plan is use a sealer 1~2x a year as normal maintenance to having natural stone.
    My brother has the same setup and honestly hasn't sealed his stone in over 6 years and there isn't any abnormal corrosion like you might see with limestone in a salt pool. He did tell me that we washes down his deck and stone on a regular basis when the pool gets high usage, but has never used a sealer.
    I'm going to play it safe and seal my stone with the water based sealer my PB recommends that will run be about 75.00 every time I seal the stone.
    Martin,
    Midlothian, TX
    That looks beautiful!! I am now second guessing my tile choice.. LOL! THANKS!
    My brother has a salt water pool and hasn't had any issues with his stone either. He sealed it when it was new 10 years ago... and that's the only time. Hopefully both of ours will hold up as well!
    Helen
  20. Back To Top    #20
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Wow, that's looking nice, I really like the rounded spa edge.
    Are you getting a beige liner, beige would look so great!
