Results 1 to 14 of 14
Thread: Blue Liner has been de-colored by Chlorine
    Hi,
    all.I must say this forum has some interesting posts and I have also founf a couple of nice hints for myself. Maybe someday I'll be able to help a newbie .
    Anyway I stuffed up the liner. Stupidly I put in slow sloving chlorine. The pool was cloudy so I didn't see it deposit on the floor. Bottom line is that when I finnally got the water crystal clear I saw the damage.
    The chlorine has taken out the color of the liner and has even eaten out part of it !! Now I have a large white stain on the bottom. Large I mean about 2m X 1m white stain.
    Question is.....can I do something about it without replacing the Liner. I was thinking of solutions like:
    1) Paint the area. I've seen paint for pool ( I think it usually goes con cement pool and spa's)
    2) May I can put a large patch on it. Something along the lines of a repair kit only very bug.
    3)Stickers? Maybe something I can apply on the liner.
    4)home made solution. Buy a piece of liner. Cut it out .Put in on the liner and glue it with an appropriate glue.
    Any Ideas are welcome.
    Thanks
    Carmelo
    22,553
    Re: Blue Liner has been de-colored by Chlorine
    Welcome to TFP.
    While it might be possible to patch over the place I'm not sure it's feasible. I don't know of any coloring that you could put over it that would work.
    Thanks for the welcome.lets see of someone comes up with a solution
    How about something like this:
    http://www.askalanaquestion.com/pool_art.htm
    No install, affordable and big enough to cover your stain.
    Just an idea....
    14'x28' with a 6' deep end- 14,500 gallon Inground Vinyl Liner Steel Pool, currently under construction. Currently shopping for bleach :)
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Quote Originally Posted by layman
    Just an idea....
    That is a really neat product!
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Thanks...I was looking at some like this also...
    http://www.skine.us/
    Should do the trick
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    The skine is clear.behind the printed areas. I had damage like what you described. I left it foe while but in the end, I had to replace my liner. I had a large white alligatored area where a chlorine puck had fallen in my Green mess of a pond.
    -- Guy --
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Can these be installed in an above ground pool? I love the look!!!
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    According the almost English (mostly French-lish) version of the website, they can be used on ABG pools. The site I was at did not sell them. I did a real fast search for dealers and I could not find one but several blogs chatting them up. I didn't look to hard. I did like the ones at the first site. I think I even saw on TV a pool that had one of them in the pool. I think it would look great in the center of my round pool.
    -- Guy --
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Techguy,
    "I never backwash. If I need a recharge, I open and clean the fingers, everytime. I takes me less than 30 minutes to do." What does this mean in your signature?
    Installed May 2011
    BBB method
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I have a Hayward Perflex DE filter. It is similar to this one, but larger. Pardon me if I am overly "simple" but I don't assume you know what I mean this way.
    I chose this image as you can see the pump (black on the right) and filter body (putty colored with the black cover on the left). The suction line from the pool is attached to the threaded section on the right, just below the clear strainer lid. The water enters the strainer basket and then the pump's impeller behind it and then out to the filter via the union between the pump and filter. This means I do not have any hoses or long pipes between the pump and filter. It is less than six inches long. The water is then filtered through the fingers shown below (this one is dirty). The fingers are part of the head assembly of the filter and point down. They are covered by the DE media (a white powder-like substance) when the filter is running. The large black part of the filter is a cover I normally remove while I am cleaning. Mine is rounder than these so it tends to roll over like a turtle on its shell.
    The filtered water exits the filter and returns to the pool via a fitting and hose at the black circle near the top of the filter pictured above. The filter can have a backwash valve and pipe/hose added at the bottom left of this filter, just above the black base.
    When the filter gets dirty from filtering the junk from the water, the pressures rise and the water flow decreases. When the DE gets so dirty I cannot run it more than 30-90 minutes without the pressure rising too much, I change the DE. I could use the backwash valve and "wash" the DE media out of the filter body and down the backwash hose. The challenge is, for me, I don't have a good place to run the backwash too. I could dump it on a lawn if I don't mind the DE on the ground, the DE can be considered a hazard in certain circumstances or I could wash is down the sewer... but it is too far from my pool to a good place to do that AND only 80% of the media washes out so the filter is always 20% dirty.
    So... what I do is I take all the hose off the pump and filter (two hose clamps and two minutes of work) and I unscrew the filter from the pump via the union between the, I then let the DE settle to the bottom of the filter body. While it is settling, I take the head off the filter and wash the DE and junk off the finger so it look like this when clean.
    I then pour off the water from the top 2/3 of the filter body and dump the remaining dirty dirty DE into my green waste garbage can for composting. I wash all of the filter parts, rebuilt the filter, connect the hoses up and add the DE and I know I have a 100% clean filter. It takes me less time to do this than to hook up a backwash hose and do the 80% effective backwash, and clean up from the backwash and any resulting mess.
    Sorry for the long answer.
    -- Guy --
    jule's Avatar
    New London, Wisconsin
    139
    ~ techguy ~
    I confess I didn't read through your cleaning process, but your 'filter fingers' look 'sea monster creepy' to me. Can't begin to imagine them full of green slime and baqua yuk.
    My 14 cartridges don't seem so bad now.
    22 ft octagon, inground, 4 ft ave depth - figured @ 11,400 gallons, well water
    Steel walls with sand bottom and vinyl liner : under full sun
    Harmsco Betterfilter w/14 paper cartridges
    1 hp Hayward motor
    Baqua to Chlorine in 2010.
    ~Wisconsin~
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I do enjoy being able to go all season with one bag of DE for about $25. I hated my cartridges with my Intex pools.
    -- Guy --
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Thanks for the explanation. I was imagining everything but what you posted.
    More Education!!!! Love this site!!!!!!!!!!!
    Installed May 2011
    BBB method
