Thread: Switched to Bleach
    Jul 2012
    North Atlanta
    22
    Switched to Bleach
    Hello
    I recently closed my chlorinator and been adding 1 bottle of bleach every other day
    I'm in Atlanta and it's hotttttt
    Is this normal??
    18x36 ig Vinyl 26000 gal
    30 Jandy Sand Filter
    2hp Pentair Challenger
    Hayward Chlorinator
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Re: Switched to Bleach
    Yes, it's normal for Atlanta to be hotttttt in the summer.
    Sorry...couldn't help it...
    In any event, since you did not post your CYA level, size of "bottle" you're using, or concentration of bleach being used, we have no way of knowing if that's "normal". Please give us that information, along with a full set of test results, and we can try to help you evaluate your chlorine usage.
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    Feb 2008
    Denton, TX
    5,061
    You have a large pool. I'd say that if you are getting away with adding a 182 oz. bottle every two days, that's pretty good. As the previous poster mentioned, the CYA level makes a difference. You might be able to bump your CYA up a bit to help, but not knowing what your CYA is, it's hard to make suggestions.
    Jul 2012
    North Atlanta
    22
    Thank You All I will be getting a Taylor Test kit asap
    Hayward Chlorinator
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by hotlanta
    JIC you haven't seen it, here's a link to recommended test kits compared: pool-school/pool_test_kit_comparison
    The fav around here is the TF100.
    You're done SLAMing when:
