Thread: Height/Width of Counters and Bar for outdoor BBQ
    All,
    Love the photos of the projects on here...i am putting in a BBQ/Kitchen by my pool and am looking for advice on heights and widths for counters and bar...I have a basic drawing of what I am planning and have measured it out as to the basic lay out but am looking for input on how deept to make the counters and how high the counters and Bar top should be...Any help on standards used would be great....
    Thank you
    Bart
    Riles_J's Avatar
    Nashville, TN
    218
    Re: Height/Width of Counters and Bar for outdoor BBQ
    These answers somewhat depend on the layout and the type of equipment you plan have installed. My island has an average depth of 30-inches. Height is a little over 36-inches. I was shooting for 36-inches but the height of the equipment plus the height of my concrete counter pushed me over that an inch or two.
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    in the other thread "how much per ft?" mine is 36.5" high to top, 40" wide with 9" overhang for "bar" to sit at.
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    Aug 2010
    New Caney, TX 77357
    184
    When researching for my build (nearing completion) I found these guidelines below on http://www.grillkitchens.com:
    ____________________________________________________________ ____________________________
    Common Design Measurements:
    Finished Counter Height: 36-38
    Counter Depth: 30-36 (Appliance Specs will Determine)
    Bar Height: 42-44
    Bar or Table Seating: 24 Per Chair
    Legroom 15 Minimum
    Counter Workspace: 24 Minimum*
    * Recommend same as appliance cutout i.e. a 30 grill and 24 sink should have a minimum of 54 counter.
    ____________________________________________________________ _____________________________
    I also found that 36" countertop height is standard in the kitchen and considered both the "optimal" and most ergonomic height.
    I made my countertops 36" high, bar height is 42". Countertop depth is 30-32 inch (depending on which section) with 6" backsplash height.
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
