Thread: Plumbing a Slide
    Plumbing a Slide
    Hey folks,
    I plumbed in my slide so that I wouldn't have to deal with a garden hose anymore. When I turned it on though, I was only getting a trickle of water coming out, despite having great water flow in my pool.
    I see 2 potential problem points so wanted to see what you guys think is more likely the culprit.
    1) The 1/4" tubing starts by my equipment and goes through 100' of 1/4" tubing before getting to the slide. Would I be better off using 3/4" for the 100' and then switching to 1/4" by the slide?
    2) The T that I used to plumb in the slide has the 1/4" tubing coming out the right side. See below:
    | |___
    |..___
    I figured the pressure would be enough that it wouldn't matter, but do I need to replumb it so that the T is facing down? Like this:
    _________
    ___...____
    Thanks!
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Plumbing a Slide
    you could plumb a valve past the T for the slide to force the water to look for a path of least resistance (your 1/4" slide). I just wouldn't close that valve all the way. ( a gate valve is good at slowly closing)
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    38,290
    The direction of the T does not matter. You problem is the 100' of 1/4" tubing which has a LOT of head loss. If you can use a larger pipe to the slide and then switch to 1/4", I think you will do better, but you still may need to add a valve after the T to better force the water through the smaller pipe.
    I do actually have a valve past the T but it's a jandy valve, so full on or full off. I can easily test out the larger tube line though. Might cost a bit to test, but if it does the trick I'll be happy.
    Thanks!
    38,290
    Jandy valves are not just full on/off. Just do not turn out all the way. A picture could help confirm though.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
