Thread: need advice for new sand filter /pump
    Jul 2011
    S.W. Ontario, Canada
    23
    New AGP this year, 15' round 52" deep 5000 gal
    currently using a " GAME Sandpro 75 sand filter / pump which has a constant leak around the top ring
    which seems to be a common problem.......... the ring and gasket has already been changed twice and its leaking again.
    Im looking at poolsuppliescanada.com as im in Ontario, Canada
    any suggestions ?
    i was looking at the Hydropro 19" for $139 + $28 shipping and using the existing 3/4hp pump ?
    any preference for Hayward over Hydropro ?
    2012 new 15' x 52" round sharkline above ground, DIY installed & BBB maintained. 3/4hp with 19" 150lb sand filter, 4 x 20 sungrabber solar heater. DIY solid piped.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: need advice for new sand filter /pump
    Quote Originally Posted by repsolal
    That should work well for your pool (though I don't know what pump that is on the sand pro).
    I am not familiar with hydropro, but sand filters pretty much work the same way, so either should work.
    Jul 2011
    23
    The new filter arrived the next day and i hooked it up the next day.
    Seems like a decent unit for the price. Local pool ripoff store only had a jacuzzi 19" in stock and wanted $368 for it
    when poolsuppliescanada had it for $209 ! so im glad i ordered online.
    The sandpro pump was connected to the filter with a 1 1/4" flexible hose, I used the old pump but connected
    it to the new hydropro filter with 1 1/2" PVC pipe........... the difference in the pressure at the return is amazing !
    If I open the valve for the fountain wide open it actually spurts right over the pool and onto the lawn at the other side !
    with the existing setup it did not reach the other side at all !
