Results 1 to 9 of 9
Thread: Requesting help with CYA reading
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Hello everyone,
    I set up my pool exactly 2 weeks ago - 8000 gallons. Added 63 ounces of stabilizer expecting it to raise my CYA to 60. My reading a week ago indicated a level between 30 and 40. Today's reading shows close to 30. Have I miscalculated what 63 ounces should do to my pool? Thanks for any advice you may offer. Here is the stabilizer I used.
    http://www.canadiantire.ca/AST/brows....jsp?locale=en
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    38,243
    Re: Requesting help with CYA reading
    You calculations were correct. Does the bottle list a strength? Every once and awhile we run across some weak stuff.
    Jul 2011
    844
    The bottle does not list a strength. It does not give any useful information on the bottle. It does not even mention CYA anywhere. I assumed it was CYA. It must be or I would not get a reading at all I assume. I did not realize it could be weaker. I assumed CYA was CYA. I assumed stabilizer was CYA. I will take another reading to be certain.
    Bestway SWG
    Jul 2011
    844
    Just tested again to be certain, and I'm confident that the reading is just above 30 on the view tube.
    Bestway SWG
    Jul 2011
    844
    Do you folks think I should trust this reading? Or s it possible I have weak CYA? I am fine with the 30 ppm if I know I can trust it. i just don't want to add and find out later that I have to much CYA. Is it possible the reagent is bad? I purchased it in August of last year.
    Bestway SWG
    30,403
    Trust the test.
    Even though it is a little old, that reagent is inert and should give you a valid result unless you have compromised by storing it in heat or cold.
    I have never seen a package of CYA that doesn't list the ingredients but it sounds like you got one.....I'd purchase another brand, calculate to raise CYA by 20ppm, and then test.
    Jul 2011
    844
    Thanks duraleigh. I'll trust the test. Yep, there is absolutely no information on that bottle. And I can't find any other stabilizer. I will have to go to the pool store. ARRRGGGHHHH!!
    P.S.
    Did you get my PM a few days ago.
    GC
    Bestway SWG
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Good info, helped me out too.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Jul 2011
    844
    UPDATE:
    Just wanted to post this update. I found some information on the container (in about a 1 point font!!) for this CYA which tells me to add 300 grams to 10,000 liters of water to raise CYA by 30 ppm. Sorry for the metric but I'm in Canada! If my math is correct, then my CYA level should be at 90 after adding 2,700 grams. But it is at 50, indicating a weak batch of CYA. You guys were dead on.
    Bestway SWG
