Thread: Another newbie.
    Jul 2012
    Ohio
    1
    Another newbie.
    Like most I found this wonderful site AFTER buying my pool and start-up kit.
    We bought an Intex Easy set pool (10' x 30") with a filter pump. We also purchased (& opened ) an HTH pop-up pool start up and maintenance kit. It came with shock 'n swim, chlorinating granules, stabilizer & conditioner and 4-way test strips.
    After reading through the instructions I did a test and came up with FC - 0, PH-8.4, and TA-240.
    I was fortunate, after not knowing where to start I ran across the pool calculator. I added 1 oz of the chlorinating granules but then realized that i need to adjust the ph. I guess my question is, what do I need to put in after that or should I have done something else?
    24' x 54" AG vinyl approx 13,800 gal
    Waterway Clearwater ll Cart Filter Deluxe System 2 speed pump
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Re: Another newbie.
    get your ph set. the your stabilizer (CYA) and get chhlorine in there..
    that would be my suggestion.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
