Results 1 to 8 of 8
Thread: Fountain heads/nozzles?
    Aug 2010
    Austin, TX
    200
    I've been looking everywhere for more interesting fountain nozzles fort he kids. My PB put in three fountains, that are essentially a screw-in PVC pipe with a regular 1.5" return eyeball on the end.
    I was thinking there would be all sorts of nozzles one could screw in, but the the life of me I can't find them.
    Any ideas/pointers?
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Fountain heads/nozzles?
    Here's the one I have I like.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    I googled and found a few - this one looks neat...
    http://www.intheswim.com/Pool-Accessori ... -Fountain/
    Aug 2010
    Austin, TX
    200
    Thanks guys. That's not quite what I had in min but great options.
    The PB put a standard 1.5" eyeball return in the floor of the hot tub and kiddie pool. Then they put a PVC extension into the threaded return receptacle and put the eye-ball on the end of it. I can screw in any standard return nozzle into the end of this PVC. To me this would be as simple as deciding you want different hot-tub jets....but I can't seem to find any nozzle designed to be fountain heads.
    This is the nozzle I have now (similar) http://commercialpool.com/returnfitting1534eyeball.aspx
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by shakenbake
    Could you take something like this http://www.epoolshop.com/1-12pipeplugwitho-ring.aspx
    and drill small holes through it to make your fountain?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Why reinvent the wheel, as msgtdan posted a few days ago? Put a reducer on the pipe and get you one of those fancy showerheads with multiple spray patterns.
    Shower head? Sprinkler head?
    mwitt21w
    20000 gallon fiberglass, Pentair Clean & Clear Plus 420, Pentair Whisperflow WF-23, Pentair Intellichlor Generator
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by derekc
    Either. Or drill your own holes in a pipe. Search Aerator or Cooler and look for the paper clip icon for more pictures.
