Thread: First water test results
    Apr 2008
    San Carlos Mexico
    45
    I tested the water for the first time today and it revealed the following numbers
    FC 1.5
    CC .5
    TC 2
    ph 7.3
    TA 150
    CH 800
    CYA 120
    temp is 72
    With what little I know this is telling me to do a water change. Should I do 2 draw downs of say 25% to 30% each or would a 50% be better to start? The Ch out of the tap is 150.
    Thanks this is a great forum
    30,000 gal Pebble Tec, Intellifo 4X160, Pentair 80 DE Quad, Pool Pilot SWG, Easy Touch Controls
    You want to leave at least 1 foot of water in the shallow area. Other than that two partial drains will require slightly more new water than a single deeper drain but otherwise will work just fine.
    Apr 2008
    San Carlos Mexico
    45
    Thanks Jason
    I will draw it down as you indicated. I suppose I should wait a few days and then retest to see what further action is required.
