Results 1 to 7 of 7
Thread: TA....do I need to lower it?
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    So I converted from baqua to BBB. My TA has been high since I first tested (~300ppm). So the question is...do I really need to lower it? Or only if my pH drifts too fast for me?
    18ft Round Intex Metal Frame, 7000gal, 3/4HP pump, 100lb sand filter, TF-100 Test Kit, through the wall skimmer, Baqua convert...now BBB all the way. :)
    Ugly Drum Smoker (UDS), Weber One Touch gold. (I love smoky meat) :) Saving my $$ for a Big Green Egg.
    Things I use daily:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: TA....do I need to lower it?
    doc.mosi:
    If your pH is rising too quickly and is consistently rising above 7.8 (considered the top of the ideal pH range) to the point that it is difficult to manage, then I would consider lowering TA.
    Here is a Pool School article explaining this in more detail: http://www.troublefreepool.com/pool-...l%20alkalinity
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    Thanks for the reply....I've read that pool school article...just looking to make sure there wasn't some other reason to lower the TA. Recently my pH has been fairly stable. Right now my pH it has been rising, but I attribute that to the fact that I've been aerating. I'm gonna stop aerating and if the pH is still stable, I'm letting it be...unless some else has a compelling reason to lower it.
    Things I use daily:
    The other reason to avoid high TA is when your CH level is also high. If both are high at the same time you can get calcium scaling.
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    JasonLion,
    Is that a concern with a vinyl AGP? I haven't tested CH at all, thinking it did not matter with vinyl AGP.
    Things I use daily:
    38,521
    yes high CH can result in scaling in any pool. Low CH does not matter in a vinyl pool.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    Guess I'll be checking CH tomorrow. Thanks for the info.
    Things I use daily:
