Results 1 to 11 of 11
Thread: Stuck at Almost Clear, Need Some Help Please
    Jul 2012
    Shavertown, PA
    11
    Hi gang, I'm new to this sight and have been doing a lot of reading on the site and learned a lot, however this is my problem.
    My pool is an inground 16x32 about 20,000 gal. water.
    We just couldn't get it clear with chemicals, to make a long story short. I read a lot on this site. The bottom had a lot of leaves and dirt which i finally think i got all of them yesterday, between the leaf rake and I also used the leaf vac/bagger that attaches to your garden hose. That worked great. I added 10lbs. Cal hypo 68% shock, and today its a lot better but not clear. I still cant see the bottom. But it looks like it wants to clear. Its a slight green/cloudy.
    I took a water sample to the pool store today and they said not to add anything else, and just let the filter run and vacuum it. I still cant see the bottom i told them. He said it didn't matter From what i read/understand, your not to vacuum the pool unless you can see the bottom.
    These are his results:
    FC: 10.96
    Ph: 7.8
    Alkalinity: 118
    Stabalizer: 2 (is this CYA?)
    Calcium:280
    I thought i should be keeping the FC level at around 30 for shock level until it turns. Is this right?
    Should i add more shock to get the FC up to shock level till clear or just leave it alone and vac like he said?,
    Thanks Guys, your forum rocks,
    Van
    24k IG vinyl pool, Hayward Pump: SP2607X10, Hayward Super Pump Motor 1HP, Hayward Sand Filter
    TF-100 test kit
    30,415
    Re: Stuck at Almost Clear, Need Some Help Please
    Welcome to the forum.
    Well, if the pool store's test result of 2 for stabilizer is accurate, then you would be at shock value already.
    The problem is there is no way you can put any trust in that CYA test. CYA is measurable @ 20ppm at the lowest and 100ppm at the highest but not detectable @ 2ppm. It's a bogus test result and the other results may be, also.
    You have started to shock the pool but have not completed it...it may take a few more days.
    Testing yourself is really the only way to get credibility into your results. We can guess what to do along with you, but it is simply guesswork without good results.
    Jul 2012
    Shavertown, PA
    11
    I forgot to mention the filter is a Sand Filter, and the water is Regular, Not Salt. Not sure if this matters, but I want to give you as much information as possible.
    One thing i missed on the bottom of the readout was the Phosphate level says 500 ppb,
    Thank you again,
    Vandan
    TF-100 test kit
    Jul 2012
    Shavertown, PA
    11
    I see. I do plan on buying the test kit that you guys recommend. The TF-100. I just need to get a few more dollars together.
    TF-100 test kit
    38,271
    Dave has you covered, but wanted to add that the not vacuuming if you can't see the bottom is bogus.
    Vacuum when you want. If you have a leaf trap, then there is little risk to sucking up something that could get stuck in the plumbing.
    Get the kit, best investment you can make to controlling your pool.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Apr 2012
    SW Ohio
    456
    Yea what jblizzle said......lol
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Jul 2012
    Shavertown, PA
    11
    Ok, just ordered the TF-100 Test Kit. Will post results when i get it,
    Van
    TF-100 test kit
    Apr 2012
    SW Ohio
    456
    EXCELLENT.....LOL
    Jul 2012
    Shavertown, PA
    11
    Ok, Test Kit came today. TF 100.
    FC: 10.5
    CC: 5.5
    TC: 16.0
    PH: 8.0
    TA: 140
    CH: 180
    CYA: ?? Tube was filled and still could see the black dot. So it's below 20. Pool Store test a few days ago said it was "2". Don't know what test they use to get a reading that low.
    Anyway, the pool just turned a blueish color today. I add 6, 1lbs. bags of cal hypo 68% shock last night and tested tonight, 24 hrs. It's at shock level which is good cause it was mad green. I'll probably keep it at shock level for another day or so than start bringing it down, this ok?
    I still cant see the bottom, it's like a cloudy blue color.
    What should i start adjusting first after the FC level comes down, or now, dunno? Get the cya up? TA a bit lower, CH a bit higher.
    What would you recommend for an adjusting process/first to last?
    Cheers,
    Van
    TF-100 test kit
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I would say keep adding chlorine when you levels drop below shock. I would even suggest you do it tonight as much as it will take.
    -- Guy --
    Apr 2012
    SW Ohio
    456
    I might suggest go read pool school shocking your pool, with the amount of cc and the water being cloudy I think you have a ways to go before you are done shocking your pool......Mike
