Thread: Leak on Start Up of Pump
    We had a leak over winter, which was solved as it was the niche on the pool light. Now it seems when the pump first turns on, we lose 1/8-1/4 inch of water. We do not seem to lose any additional water throughout the day or overnight, just when the pump is initially turned up.
    Any ideas as to which lines to check?
    TIA.
    18x36 IG Vinyl Grecian Lazy L (20k gallons) ~ Whisperflo DS 2.0HP pump ~ QuadDE100 filter ~ Autopilot SWG DIG-60 ~ (7) 4x16 solar panels
    30,431
    Re: Leak on Start Up of Pump
    What happens if you turn the pump on/off several times during the day...is the effect cumulative?
    No the leak is not cumulative. Our guess now is that it is on the return side and the hole initially lets water out but b/c of the force of the water afterwards the initial start, little gets through. Or the when the hole sits over night with no pressure, it leaks underground.
    Husband is going to dig around the equipment pad this w/e. He had pulled some landscape stakes out a few weeks ago and replaced the outline of river stone with pavers instead. Wonder if one of the stakes had been "nailed" into a pipe and was "sealed" until DH removed the stake. The landscaper had punctured a pipe closer to the pool two years ago when they had completed the landscaping. Let's hope it is that easy which would also be an easy fix.
