Thread: Cleaning behind pool light held in with light wedge
    Feb 2011
    Portland, OR
    51
    My pool light is held in by a light wedge and I would like to clean behind the light. Does anyone know how to get the light out of the niche and once I get it out how do I get it back in?
    Years ago when I was using baquacil water mold grew behind the light. I haven't had any problems since switching to a swg but I would still like to clean it just to make sure nothing bad starts growing back there.
    10,000 gal Inground Fiberglass Pool;Aquarite SWG; Hayward H Series Gas Heater;
    Hayward Sand Filter; 1.5 HP Hayward Max-Flo VS Pump; Dolphin Pool Cleaner; TF100 Test Kit
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Cleaning behind pool light held in with light wedge
    you just unloosen the screw on the light wedge and pull out the light, when putting it back in make sure you have the excess wire behind the light in a spiral so there is room for the light to fit back into the niche. There is usually a spot on the bottom of the light that fits into the niche first (like a hinge) point then the rest of the light sits flush and you re-tighten the screw on the light wedge.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Feb 2011
    Portland, OR
    51
    Thanks, I will give it a try.
