Thread: Test Results in - Is FC what I should focus on?
    Jul 2012
    Mississippi
    4
    My TF-100 came in today and I've tested my water. Here are the results:
    FC 1.0
    CC 3.0
    TA 180
    CH 300
    CYA 80
    PH 7.8
    I've already started the shocking process, aiming for a shock FC of 30, since my CYA is 80. Am I on the right track? Should I be concerned with any other levels at this point, or wait until the green swampy is gone?
    Also we are filtering 24/7, brushing walls, using leaf rake.
    I'm off work the next two days. If I test more frequently (every two hours perhaps) and replenish the FC to 30 more frequently during the day, will I get results faster?
    Thanks for the advice!
    29,000 Inground Vinyl liner
    SWG
    38,275
    Re: Test Results in - Is FC what I should focus on?
    if you are going to accept that high CYA, then you are right, keep the FC up and follow the shock process.
    I would consider replacing 25-40% of the water to let the CYA to a little more manageable level, but not totally a necessity at this point.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Feb 2008
    Denton, TX
    5,061
    ...I would consider replacing 25-40% of the water to let the CYA to a little more manageable level, but not totally a necessity at this point...
    Agreed.
    Much easier to run the shocking process with a lower CYA.
    Quote Originally Posted by jtammy
    FC 1.0
    CC 3.0
    TA 180
    CH 300
    CYA 80
    PH 7.8
    FC of 30 is correct @CYA 80
    With a SWG, 80 CYA is at the top end of the chart.
    http://www.troublefreepool.com/pool-school/chlorine_cya_chart_shock
    19000 gal gunite,
    600 gal hottub,
    Intelliflo variable speed pump,
    Pentair 420 filter,
    Pentair 400k heater,
    Hayward Navigator Pro,
    TF-100
    Speed Stir ->->-> Great tool for easy testing
    30,419
    Yes. You will experience less and less FC loss as the process continues so you won't need to do it that often more than a day.
    Butterfly's Avatar
    South Carolina
    10,045
    You should lower the pH to about 7.2 before you start the shock process.
    You're done SLAMing when:
