Results 1 to 8 of 8
Thread: brand new motor wont start
    Hi I am new here. Followed each step of instructions carefully to set up brand new sand filter. Ran the backwash and that went perfectly. Turned off the pump. Switched to rinse. Now The motor will not start. It is plugged in to a grounded circuit. Please help? Thanks very much!
    Summer escapes AG 16'
    Intex sand filter 14
    Sep 2011
    Omaha, NE
    95
    Re: brand new motor wont start
    Since this should be on a GFCI, did the breaker pop on the outlet and need reset? Or the main breaker at the panel?
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Some here have mentioned their GFCI tripping when cycling their pump. Sounds like yours tripped, and needs to be reset.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    A little outlet tester like this one is REAL handy to have lying around.
    [attachment=0:3rcvp7gn]outlettester.jpg[/attachment:3rcvp7gn]
    The GFCI passes the test. But working on it again...the on off timer button does not seem to be "clicking" when pressed as it did before. Have there been issues with the power buttons?
    Sep 2011
    Omaha, NE
    95
    Does your pump have a built-in timer or is there a separate timer on it? My (external)timer went bad before. If so, disconnect the timer and plug directly into the outlet...
    16X24 Oval Doughboy
    10,000 Gallons~
    I have an internal timer. Ended up taking out the power toggle. It was actually jammed! So problem solved and its working great. Thanks!
    Sep 2011
    Omaha, NE
    95
    Glad you got it working!!
    16X24 Oval Doughboy
    10,000 Gallons~
