Thread: SWG and travertine
    May 2012
    San Jose, CA
    141
    SWG and travertine
    Any thoughts about a SWG with a travertine deck?
    I have read elsewhere mixed results on whether the travertine will hold up. If someone has experience, it would be appreciated. We have travertine going in and I'm scratching my head which way to go to chlorine the pool.
    thanks, Phill
    24k gal 16x38, spa 7x6, Colorscape Caribbean Blue plaster, Pentair Intelliflow, Hayward jacuzzi air pump, Pentair 520 filter, Raypak 336k cu-ni heater, Aquabot Turbo T... pool remodel finished 8/2012.
    Re: SWG and travertine
    My sw pool is one year old and the travertine deck has no sign of wear/damage.
    Size 12,000 gal | Filtration Jandy 340 CL Cartridge | Sanitation Jandy 1400 AquaPure SWG | Placement In-ground Gunite | Finish Medium Gray Plaster | Automation Jandy Aqualink RS w/PDA6
    Pump Jandy 2.5hp 2 speed Stealth | Location New Orleans LA
    Heat Jandy EE2000t
    Test kit Taylor K-2006 (fas-dpd)
    mmn's Avatar
    Jul 2013
    South Florida
    34
    Quote Originally Posted by Raider4251
    I realize this is an old thread, but I'm pondering the same thing with a new travertine deck and coping. Did you seal it or is it raw?
    Regards
    Michael
    14,288 gal IG freeform Diamondbrite
    Hayward 9002 filter
    3/4 hp Hayward pump
    Barracuda G3 cleaner
    TF-100 test kit
    resurfaced 6/2013
