Results 1 to 10 of 10
Thread: Stabilizer question
    May 2012
    Melbourne, FL
    17
    Stabilizer question
    Well my pool has been doing great with tfp's help it has been crystal clear! But I did another water test at ace yesterday and my cya is sitting at 13 even though I know the tests are off it was at 37 in my last test. I'm assuming this is why my chlorine has been burning off so quickly. My question is what should I add for stabilizer? Is there a liquid stabilizer I can get locally so I don't have to mess with the shock granules? Thanks in advance!
    3100 gallon - Round Intex AG - 1000gph intex pump -
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Stabilizer question
    Yes, if you cya level is 37, then your chlorine loss to the sun will be reduced if you go up to 50 ppm.
    I like the price of the granules, so that is what I use. The liquid stabilizer is fine to use though...much more expensive.
    May 2012
    Melbourne, FL
    17
    Quote Originally Posted by linen
    My cya is at 13 according to the test I did yesterday. It was 37 on the previous test. I'm aiming for 40 cya atm. How much of the granules should I add then to bring it up to 40? I had problems getting them to dissolve last time though which is why I asked about the liquid.
    38,354
    hard to say how much to add since your test results are so different.
    Your best investment would be your own test kit. See link in my signature for the kits we recommend.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    oops, I assumed the 37 was your own test. Follow jbliz's advice and get your own kit. The pool store results are notoriously unreliable, especially for cya.
    May 2012
    Melbourne, FL
    17
    I would get a test kit with cya but just can't afford it atm. I'm sorry if I wasn't being clear about the test results. The water tested at 37 cya about a month ago. The new test at 13 cya was yesterday. I've had to drain water out a few times due to rain.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You could start with the 6-way drop based test kit at walmart. You can do about 2 cya tests with that.
    Draining rain water will reduce you cya level, although probably not much each time.
    May 2012
    Melbourne, FL
    17
    Those 6 way kits weren't available locally so I ended up with a 4 way kit from home depot. Thanks for the help I'll see about getting some granules.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I assume that 4-way doesn't do cya?
    May 2012
    Melbourne, FL
    17
    No it does not. Being a small pool it should be alright for now just needed to workout my cya.
