Results 1 to 8 of 8
Thread: how much bleach ?
    how much bleach ?
    We tested our pool and it needs 12 lbs of shock it. We filled it with creek water. How much bleach do I use instead ? I'm new at this. TIA !!!
    Artesian pool 24' x 54'' buried in ground
    Pentair Dynamo 1.5 HP pump
    200 lb SD-60 Pentair Sand Dollar filter
    Taylor K-2006
    38,460
    Re: how much bleach ?
    have you read Pool School?
    Do you have a recommended test kit?
    You can not follow the shock PROCESS as described in Pool School correctly without the correct test kit.
    The Poolcalculator will calculate what you should add, but it is not a good idea too blindly throw in a massive amount of "magic powder"
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    How much bleach depends on how much water and how high you want to take FC level.
    We haven't ordered our test kit yet. It was just filled. The pool store tested it . They are who said we needed 12 lbs of shock. It is 12,000 gallons. The free chlorine is 0. Total chlorine 0. PH 8.8 total alkalinity 125 total hardness 46 . They had us add 3.25 lbs of Lo N SLO and bottle of algecide.They say we need 12 lbs shock. I want to order a test kit and get the BBB method going. Where do I start while I wait on my kit ?
    Taylor K-2006
    Richard320's Avatar
    Jan 2010
    19,051
    I hope that "shock" isn't dichlor - you'd overload on stabilizer and bleach out your liner.
    Pool School. Once you understand what each parameter means and what each chemical does, you won't need to ask.
    38,460
    pool store testing is notoriously bad. So if you have no testing ability yourself there is not much you can do.
    Correct steps would be:
    Get pH in mid 7s
    Get CYA up to around 30ppm
    Follow the shock process
    Note that algaecide and phosphate removers are a waste of money and not needed if you keep the correct FC level for your CYA level.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    In the mean time----start by posting a pic for us of your 24 ft. "in ground" pool!
    22,553
    12 lbs of dichlor will raise your CYA by 56 & your FC by 61. 61 ppm FC in an unstabilized pool will definitely damage your liner. Cal-hypo would be even worse.
    I hope you didn't add that much. You only need 1.5 large jugs of bleach to get to shock level.
