Thread: water issue
    water issue
    I've been fighting algae in my 16 x 48 AGP for a couple of weeks. Yesterday, we hooked up our upgraded filter/pump. At that time, I checked my levels. My water was greenish. I am using the 6way test from HTH. My TA level was high (200), the PH was 7.8). I added more bleach and ran the new pump/filter all night.
    This morning, my water is now bluish/green and seems to be a little clearer. My TA is now 150 and the PH is 7.2. I can barely see the bottom of the pool...so I'm thinking I just need to give it time....
    My question is the color of the water. Is my goal to have the water white/chalky colored? I think I read that if it is still greenish, I haven't killed all the algae? Am I correct? If so, I would need to add more bleach. According to my test, it's reading 5+ (really yellow!)
    Also, I also took a sample to Leslie's (just to see if my #s were the same as theirs--they were very close)... Since my calcium level is low (80)...they are STILL saying I need to up it. They say its causing my cloudy water. From what I read here, that just isn't correct. Right??
    16 x 48 Intex Ultra; Intex 1600 sand filter/pump;
    TF50 test kit
    Crosby, Tx
    38,521
    Re: water issue
    You are not correctly following the shock process as described in Pool School.
    Also sounds like you do not have the correct test kit to actually follow the process.
    You need to have the FAS-DPD test to measure high FC and CC levels.
    Correct. Ignore the low CH in a vinyl pool.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Apr 2012
    SW Ohio
    456
    Re: water issue
    how to do this in order
    1. order tf100 test kit or k2006 test kit
    2. while you are waiting on test kit to arrive read an re-read pool school
    3.read how to properly shock your pool
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    Re: water issue
    i may also add stock up on 6% bleach and baking soda and borax if you are going to be using the BBB method and also get a gallon of muratic acid and some stabilizer and a old sock so when your test kit arrives you will be ready for battle......Mike
    P.S re-read POOL SCHOOL.....LOL
    Re: water issue
    I just ordered the TF100 test kit--should arrive sometime next week. I already have lotsa bleach, 20 mule team borax, and muratic acid. Since hooking up my new pump/filter last night, just backwashed green water. So I know it's doing it's job... Guess I'll just keep the filter system running 24/7 until everything clears...
    I realize it's gonna take time,but do I need to do anything else?
    TF50 test kit
    Crosby, Tx
    38,521
    Re: water issue
    Your pH looks fine (make sure it is in the mid/low 7s before starting) ... just need to start the shock process ... once you know your CYA level and FC shock level.
    You can continue to add a bottle of bleach every evening until your test kit arrives.
