Results 1 to 13 of 13
Thread: What do I need to do?
    hdross's Avatar
    Jun 2012
    Marshall, Mo.
    15
    I tested my chlorine this morning and it was
    FC 2
    CC 0
    I added 182 oz. to bring it up to 6 according to the pool calculator.
    I also vacuumed and brushed the walls.
    I re-tested to see if I was at 6, and this is what I found
    FC 3
    CC 2
    I added 3 96 oz bottles of Menards bleach. Should I bring it up to Shock level, or wait and do the overnight test?
    18 / 36 IG pool
    22,000 Gal.
    Vinyl liner
    No bottom drain, De filter
    30,432
    Re: What di I need to do?
    Please post theother test results we need..
    pH
    CH
    CYA
    TA
    38,524
    with CC that high, no point in doing the OCLT. You need to start the shock process, after confirming your pH is in line.
    Post up the full set of tests.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    hdross's Avatar
    Jun 2012
    Marshall, Mo.
    15
    The PH was high 8.2
    TA 190
    Borates 15
    CYA 25
    According to calculator I need to add 100 oz muratic acid!
    Also gonna add stabelizer
    18 / 36 IG pool
    22,000 Gal.
    Vinyl liner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Quote Originally Posted by hdross
    The PH was high 8.2
    TA 190
    Borates 15
    CYA 25
    You might need more than 100 ounces - anything above 8.2 reads as 8.2. Maybe you're closer to 9?
    I'd probably add a quart, brush it around, add another quart, brush it around, add another quart, brush it around, and then recheck pH in half an hour with the pump running. Or longer, if you have something else to do. Then see how much more you should add. With your high TA, even if you knock pH down to 7.4, it will likely climb again to 7.8 in a day or two.
    hdross's Avatar
    Jun 2012
    Marshall, Mo.
    15
    Re: What do I need to do?
    Thanks, I will re check in a little while. I am going to see how to lower the TA
    18 / 36 IG pool
    22,000 Gal.
    Vinyl liner
    38,524
    lower pH into the mid/low 7s
    Maybe raise CYA up to around 30ppm
    Start the shock process
    After passing the 3 tests then adjust CYA up higher and consider adding other parameters.
    Richard320's Avatar
    Jan 2010
    19,071
    Don't worry about it yet.
    TA's the last thing you play with, when everything else is balanced and you're bored. If you keep pH around 7.4-7.5 all the time, it should come down by itself.
    30,432
    X2 what Richard just said. Ignore your TA for now.
    I do not know the reason but all newbies seem VERY interested in adjusting TA when it is the least critical parameter and, in most cases, should be dealt with last. pH and chlorine should be your priorities.
    38,524
    I have noticed that too...kind of odd huh?
    Smykowski's Avatar
    Sep 2011
    3,065
    Second and third Richard and Dave.
    For now, control your pH and FC. You will be inadvertently fixing TA along the way.
    Hehe... my tap is TA550.... so, in an attempt to not buy stock in acid forever I figured why not work at it Then again, mine is crazy high... the chlorine is good but the pH is and will be a constant issue until the TA is stable. Perhaps I'm misunderstanding how TA interacts with the others but in some cases it seems we newbs may need to pay attention to in order to get to 'trouble free'
    Vogue Vectra 30' Round (21,200 gallons), Waterway 2HP 2-speed, 27" sand filter - TF100 -- Southern IL - Install 06/2012
    Last minute upgrade from 27' due to error in dealer inventory *yikes*
    38,524
    the point is you need the CYA and FC right or the pool will turn green fast. High TA will just raise the pH which could eventually result in scaling ... not an over night issue.
    It its about prioritizing the most urgent needs.
