Results 1 to 8 of 8
Thread: Intex Krystal Clear1600 gallon Sand Filter Pump/Low pressure
    Guest
    I just installed this pump as a replacement for my Summer Escapes, 15'x42" skimmer basket pump/filter and I have low pressure reading on the pressure gauge.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex Krystal Clear1600 gallon Sand Filter Pump/Low pres
    Welcome to tfp, RastaFenian
    Is your flow good going back to the pool?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Just noticed in your picture that both plunger valves appear to be closed.
    Guest
    The hose coming from the original skimmer basket and pump is 1/4 in diameter smaller then the new filter hose. I have removed the guts from the old pump as well as the old paper filters. From the plunger valve at the new pump, everything is set-up as the owner's manual requires. I added 50lbs of #20 silica sand before I back-washed and rinsed. Then I started the pump in filter mode. Is 50 lbs of sand enough? What type of readings does everyone get from there gauge?
    The flow coming from the outlet is strong and the fittings have been checked for leaks, etc etc.
    Any help would be appreciated
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If the flow is strong, then you should have no problems.
    IIRC, 50 pounds is the right amount.
    Guest
    The flow is strong and I am at around 5-7psi on the gauge. On thing I have noticed is that the older pump outlet at the liner created a circular flow. While I cannot angle the new one to do the same. The plunger valves are open.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    By circular flow, do you mean around the pool and back to the skimmer? My neighbor pulls on the fitting to one side using a bungie cord and this helps the flow to divert from straight out.
    Guest
    I think I have it all working well now. I used a rope to help adjust the angle.
    Thank for all the replys
