Question for those of you who have Jandy RS systems with a chemlink(c1900) attached. I have newly installed the chemlink and have a question.
When in pool mode all is well and the status display shows the current ORP and PH levels as expected. Also when required the chemlink will call for feeding as configured. But when switched to spa mode the status does not display anything (as if the chemlink is not connected). Is this a setup, config issue or does it work this way by design?
My intent was to automate both the pool and spa ORP & PH control.
For my pool and spa setup it has a single pump/filter with automated valves to switch from one to another. The flow cell input is mounted after the filter before any return valve so I have constant water flow into the flow cell regardless if in pool or spa mode so the flow sensor is not the issue.
Anyone have experience in monitoring the pool and spa or have thoughts on what I am missing here?
