Thread: New pool: add chemicals before pump turned on?
    maryann79's Avatar
    May 2012
    Louisville, KY
    62
    It'll probably be 2-3 hours before the water gets high enough for the pump to be turned on.
    Should I go ahead and add liquid bleach, or just wait for the pump at this point?
    I know that I have a big priority of bleach, cya and ph adjustment based on my initial test this morning. Is there an ideal or necessary waiting period between adding these chemicals?
    Thanks!
    FC=.5
    TC=3
    CC=2.5
    Ph=8
    TA=90
    CH=90
    Pool: 27' x 52" AG, about 16,500K, cartridge filter
    Waterway 175 sq ft 1.5 hp pump 2-speed
    Deck first of June!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: New pool: add chemicals before pump turned on?
    Wait for the pump.
    PH first. Give it half an hour to mix. While that's mixing, set up the CYA in a sock. Then add bleach. You can speed it all up by brushing.
    maryann79's Avatar
    May 2012
    Louisville, KY
    62
    Thanks!
    Deck first of June!
