Thread: MYSTERY ALGAE
    May 2011
    Hackensack, NJ
    2
    MYSTERY ALGAE
    Hi everyone,
    I have been having an algae problem. I don’t have all the test results but what I have is this:
    FC-32
    T/A 60
    CC-0
    ph-
    CYA 40
    No PH on the relation that it would not be a true reading due to the high FC. The water is clear. I understand that my CYA is on the low side for a SWG. It is there just to deal with the algae, and then it will go back up to 70. I have done an OCLT and passed about 4 days ago.
    I have been thru the shock process and the test results before I started were this:
    FC-7.5
    T/A 50
    CC-0.5
    ph-7.6
    CYA 40
    I have maintained the shock level above 28 for a week now and I still see what I believe to be Mustard Algae. I have read all the info in the Pool School on Defeating Algae and Mustard Algae. I brush the pool every two hours for the pass 4 days (from 6 in the morning to about 8:00pm). I only have step in the pool, no lights to deal with.
    Any help would be graceful.
    12"X24" AGP (7,700gal)
    Aquatrol-RJ SWG
    Hayward DE EC40AC Filtering System
    TF-100 test kit
    Sep 2011
    Omaha, NE
    95
    Re: MYSTERY ALGAE
    It may not be algae???? What does it do when you sweep your hand or a brush by it?
    See this thread:
    algae-or-just-pollen-and-or-dirt-t46996.html
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    22,545
    Re: MYSTERY ALGAE
    Have you ran an OCLT?
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: MYSTERY ALGAE
    Said he passed OCLT four days ago.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    22,545
    Re: MYSTERY ALGAE
    missed that! I'd say it isn't algae then.
