Results 1 to 8 of 8
Thread: Still filling!
    maryann79's Avatar
    May 2012
    Louisville, KY
    62
    Still filling!
    We're at 39.5 inches deep now. Seeing the light at the end of the tunnel :P
    And I left a floater with a puck in it last night.
    Today's first test reads:
    FC=.5
    TC=3
    CC=2.5
    Ph=8
    TA=90
    CH=90
    Heading to the pool calculator now.
    Pool: 27' x 52" AG, about 16,500K, cartridge filter
    Waterway 175 sq ft 1.5 hp pump 2-speed
    Deck first of June!
    maryann79's Avatar
    May 2012
    Louisville, KY
    62
    Re: Still filling!
    Forgot to say water level not yet high enough to turn on pump, so we've been filling since approx. Noon Friday, all through the night. Hoping water will be high enough in 2-3 more hours. Should I wait to add chemicals until we turn on the pump?
    Deck first of June!
    May 2009
    Mn
    198
    Re: Still filling!
    Are you sure your fc is only 0.5 and your cc are 2.5? If you didn't inadvertently switch those numbers, I think that getting some bleach in there would be a good idea. I'll let the experts comment on how to do that without a pump.
    Do you have 2 hoses running? Are you on a well?
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    maryann79's Avatar
    May 2012
    Louisville, KY
    62
    Re: Still filling!
    We're not on a well, but yes we just went with one garden hose. I'm sure on the numbers. FC was .5, water was clear in tester, no pink. TC was clearly 3, so CC is TC-FC=2.5 for CC.
    Is our water funky?
    Deck first of June!
    38,303
    Re: Still filling!
    should have just kept all your posts together.
    I think the CC could be due to the chloramines some municipalities use in their water. This should clear up with adding chlorine.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    maryann79's Avatar
    May 2012
    Louisville, KY
    62
    Re: Still filling!
    Pool is filled now. Pump is on high. Added Ph- about an hour ago, and Ph is down from 8 to 7.6
    The CYA sock is up and running, but it's going to take me awhile to get all that's needed in (my sock isn't that big!). Ready to add chlorine! Temp is about 80 degrees last I checked, but it's so hot outside it could be 60 and still feel good, I think
    Pump question: Should leave it on high for 24 hrs.?
    Thanks, everyone.
    Deck first of June!
    38,303
    Re: Still filling!
    probably not required but keeping the pump running well help get that CYA dissolved. Squeeze the shock whenever you walk by.
    Start adding bleach to stay above the minimum for your CYA target.
    Re: Still filling!
    We have the same liner and same brand pump/filter.. looking good! I run mine on low 8 - 12 hrs a day and its worked good, so far
    Vogue Vectra 30' Round (21,200 gallons), Waterway 2HP 2-speed, 27" sand filter - TF100 -- Southern IL - Install 06/2012
    Last minute upgrade from 27' due to error in dealer inventory *yikes*
