Thread: Clean Line solid safety cover - reviews?
    Feb 2012
    Lancaster, PA
    112
    Does anyone have the Clean Line solid safety cover?
    It is one of Pool & Spa News top 50 picks for 2012: http://www.poolspanews.com/top50prod...products4.html
    It is time for our PB to come out and measure for the mesh safety cover that we have contracted for with our build this year. But I am unsure if I wanted to keep the mesh or go with a solid cover. I think that I realize the pros and cons of each. Will my spring opening be easier with a solid cover? I was concerned about having a pump plugged in while my small dogs were in the yard, which is why I selected the mesh cover, but I am thinking now after having the pool for a few months that this won't be an issue.
    Any pros and cons that someone with experience can share as to whether I should keep the mesh cover or go with a solid cover?
    16 x 32 vinyl In-ground Lagoon; Shallow pool 3' to 5'; Buddy Seat; IntelliBrite 5g LED; Pool Pilor Digital SWG, Pentair Clean & Clear Plus 320; Pentair Intelliflo VS + SVRS; Pentair Sand Shark. My Construction Thread - Spring 2012
    Nov 2011
    Moberly,MO
    1,010
    Re: Clean Line solid safety cover - reviews?
    Go with a solid cover. If you close your pool with clear water it will open that way, a mesh cover will open to green water unless you open early in the year
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Feb 2012
    Lancaster, PA
    112
    Thanks swimcmp. Are there any negatives of having a solid cover?
    Qwaxalot's Avatar
    Jun 2012
    439
    The biggest problem with a solid cover is the snow load, and the type of deck it's anchored to. That said, a solid cover will give you a much more satisfying opening.
    With the solid cover, you really must use a cover pump.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Feb 2012
    Lancaster, PA
    112
    Thank you for your input, Qwaxalot. I think at this time we are leaning towards staying with the mesh cover, but possibly upgrading it to the deluxe UV blocking one, and planning on a late closing and early opening each season.
    Nov 2011
    Moberly,MO
    1,010
    I wouldn't even do that. The UV blocking ones imo are no better than a plain mesh. If you are going to pay to open and close the pool I would definitely go with the solid cover. You will be much happier with a solid cover.
