Results 1 to 8 of 8
Thread: intex pool slope
    intex pool slope
    hello
    i have a 3.05X76 intex pool
    on the grass but i have a littele slope (6 cm)
    how can i solve it?
    http://uploads.upng.co.il/6eef2a1ccd.jpg
    thanks for the help
    Nina Li's Avatar
    Jun 2012
    Tampa, Florida
    98
    Re: intex pool slope
    Not sure how you would get that stuff under the low posts.
    anyone?
    i want to put the palziv on the grass undert the low rods....
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    You can't just raise the supports without supporting the bottom of the pool itself.
    There is a thread here someplace where they built a really sturdy wood deck like structure to set their pool up on, I don't know the name of the thread though, so not sure how to search for it.
    I will see if I can find it again.
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    i will support the bottom also but not along all the pool
    only near the lows supports, i want to "built" a stairs
    something like this:
    but witout a space between them
    and not along all the poll i know that i get a staris in the midell of the poll but i dont care i only want to solve the slope
    thanks for the help
    Apr 2012
    Bloomsdale, Mo
    346
    I really don't know but I doubt the liner part will hold up like that, plus you will still be putting stress on the frame.
    These pools are designed to be assembled on level ground, and the bottom of the pool is supposed to be level with the bottom of the supports, trying to do anything else is just asking for trouble.
    Samantha
    ok....
    i decided to solve the slope problem with a sand
    i will put a sand on the grass and make the ground go flat
    but i have some qustions:
    1. whice sand to use? (sea sand?)
    2. how i will see that there is no slope any more witout filling the pool?
    3. how many kg of sand i need if my slope is about 6 cm and the gage is 3.05
    thanks for the help
    and agian sorry about my mistakes in my english
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    Sand will wash out most likely. Your frame will sink into the sand making it uneven again.
    I would use some landscape timbers and build the low end up even (use a long board with a level taped to it to make you get ground even -- not good at explaining this hopefully someone else can help) with the high end.
    That might let you use sand to level it out and pack it down then place paver blocks under your frame supports. Still not sure how good that would be as I am still learning on here myself.
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
