Thread: Intex sand filter pump 14" & saltwater system won't fit
    My intex sand filter pump 14" & saltwater system won't fit my intent ultra frame 12x36 pool. The pool outlet strainer & plunger valve set up and also the pool inlet nozzle & plunger valve setup are to large for the pre cut holes on the side of the pool.
    Anyone know of a conversion kit or what else I could get from homedepot?
    Thanks!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex sand filter pump 14" & saltwater system won't fit
    Welcome to tfp, Dg456
    Part 28 listed in the parts list in the manual that came with the intex pump/filter/swg should work to connect to your existing ports on the pool.
    Awesome, Ty. Will try that out
