Results 1 to 13 of 13
Thread: Adding Stabilizer...
    Received my new K2006 kit a couple days ago. Discovered my SWG pool has 25-30 CYA.
    It was recommended to me to raise that. So I bought some stabilizer in granular form.
    Instructions on the bottle: Broadcast into the pool, expect your filter to have high pressure for a few days, don't backwash it. Okay- I get it, it goes to the filter and dissolves over a few days from there.
    What I wasn't expecting: I spend 45 minutes brushing the granules around the bottom of the pool until they were pulled into the filter at the bottom of the deep end. The bottle made it sound as if most of them would dissolve, they didn't.
    Is this normal?
    Inground/liner. 22000 Gallons -- STA-RITE SYSTEM 3 Filter - IntelliPro VS+ SVRS Pump -- MasterTemp 250 Heater.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Adding Stabilizer...
    Quote Originally Posted by jaywdetroit
    Is this normal?
    Yes, it's normal. That's why we recommend tying the granules in an old sock and hanging it in front of a return. It dissolves faster, and won't clog the filter. And if you need to backwash, you won't lose any of the granules.
    Off to
    Apr 2012
    SW Ohio
    456
    Thee old sock trick.....gotta love it
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    bradntyler's Avatar
    May 2013
    Tyler, Texas
    10
    This is what I did today: I took a long piece of string and tied it around two old knee high socks and draped it across the diving board. Both socks are in the water dispersing the stabilizer.
    24k, vinyl, sand, IG with 1HP Hayward Super II
    3/4 booster for polaris 3900
    Proud owner TF-100 Test Kit
    Jun 2013
    Springfield MO
    51
    Hang it in front of a return? or just hang it in the pool?
    Also, my R0013 is one year old. Will it test accurately still? My CYA is hardly readable. Last year I was around 40 ( I think).
    KGK
    23K, IG Vinyl, Sand Filter, 1.25 HP
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Best to hang it in front of a return and let the flow help out. Hanging in the water will work, but it wont dissove as quickly. Squeeze the sock every now and then and it will go much quicker.
    Your R0013 should be fine. Its the colored regents for TA and CH tests and are most subject to going bad.
    Quote Originally Posted by KGK View Post
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    18,967
    You can hang the sock in front of a return, or set it in the skimmer as long as it doesn't block the flow and you leave the pump on the whole time. If you get flummoxed trying to figure out a way to suspend it, many people have tied it to a pool noodle or other floating toy and let that drift around.
    Jul 2013
    Waxahachie, Tx.
    442
    +1 on the sock method. I started out in the skimmer basket, then moved to the sock method infront of a return. Easier too to key an eye on.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Sent from mobile device. Beware of brevity and spelling errors!
    Isolated Spa - 345 Gallons
    Jul 2013
    Waxahachie, Tx.
    442
    I like the pink sock. .mine is plain old white
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    mine too, scared to turn the water pink! LOL!
    Jul 2013
    Waxahachie, Tx.
    442
    I guess know one told them..white socks only
    Feb 2014
    Central Minnesota
    5,080
    Love my pink soccer socks for adding CYA! They're extra long, double layered. Bought them a few years back to wear in a 5K event or something and found a great use for them.
