Results 1 to 7 of 7
Thread: de with sand filter
    de with sand filter
    do I added my de about a hour ago and the starting psi was 14 now its at 18 anything I need to do?
    please help thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: de with sand filter
    Quote Originally Posted by lisa9126
    please help thanks
    Sounds like backwash and then add some more DE to me. That's more than a 25% increase in pressure.
    According to the article in Pool School, you can expect a rapid rise in pressure because it's really clearing out the superfine stuff the sand missed.
    ok so its supposed to be high I did backwash it a little last night but this morning it is so nice and sparkling clear
    30,421
    Lisa,
    Why did you add the DE if your pool was sparkling clear?
    The pool was not clean it was cloudy with a little green
    I am new to all this pool stuff..
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Green and cloudy means you need to do the shocking process.
    Also read the article: http://www.troublefreepool.com/pool-...efeating_algae
