Thread: Polaris 380 pressure release
    Jul 2012
    New Jersey
    75
    Hey guys, is it normal for the pressure relief valve (the colored valve right next to where the hose connects to wall) to continuosly release pressure ? So far this season whenever its on the pressure shoots out (you can hear the hissing sound) I do not recall if this happened last year but tend to think not. The vacuum seems to run just fine and cleans up well.
    34000 Gallon Salt Water Pool, Jandy AquaPure 1400 SWG, Jandy Del60 Filter, Polaris 380 Cleaner
    Jun 2012
    NJ
    50
    Re: Polaris 380 pressure release
    I'm pretty sure that's there to help regulate the wheel RPM so that it cleans properly.. it's adjustable so that you can let pressure out if the wheels on the Polaris are spinning too quickly. I have a 360 and have had to occasionally adjust that valve to slow the Polaris down--it'll get moving too quickly and dirt doesn't have a chance to get sucked up and pushed into the bag.
    24,000 gallon in-ground plaster, Pentair FNSP60 60 sq. ft. DE filter @ 9,000 GPH, 2HP WhisperFlo pump, CircuPool RJ45 SWG, 399k BTU Raypak heater, built 2008. Taylor K2006C kit.
    Jun 2011
    York, PA
    35
    It may be a bad pressure relief valve. Ours has gone bad twice, from the research my wife found online it was because we backwashed with the cleaner hose attached? I now keep a spare on hand (like $15 to replace), and wait for the cleaner to start wheelying, then I just replace it. Has seemed to work?
    24000 Gallon Cool Blue Diamond Brite, 1HP Pentair Whisperflo, Hayward DE, Polaris 380 Cleaner
    Qwaxalot's Avatar
    Jun 2012
    439
    Yes, it's there to regulate pressure to the cleaner. If it's really bugging you, try pulling the fitting out and reversing it 180 degrees so it's pointing down, rather than up. You can also change the restrictor plate (the red or blue disc that goes behind the fitting that actually screws into the wall)
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
